Question about Kenmore Elite HE4 Electric Dryer
My dryer has stoped providing heat. Checked the ignitor and it does not glow. What part has failed?
  • Kenmore Master
  • 8,220 Answers
It could be the fuse which mounts on the blower next to the thermistor which judges temp or the thermistor itself could be open. Or the flame detection sensor might be open and not allowing power to the ignitor.
SERVICE MANUAL
Note: Use the manual to find the tech sheet and use the tech sheet to find the fault.
Posted on Dec 05, 2012
  • 2251 Answers
SOURCE: kenmore 110 74842400 runs but no heat ignitor does
check the thermal fuse 3392519 located on the blower wheel housing,if the dryer hasn't had a clean out and lint is everywhere most likely it will be the fuse,check it with a meter,pull one of the wires off and read it out,your model number shows the filter on top so unplug the dryer,pull out the filter,take out the two screws on top where you pulled out the filter,take the vent line off and take off the back panel,on the left you'll see the duct that the filter slides into,take out the four screws holding it in and clean the duct out,when you put it back on look to the right and down around 4 inches up off the floor and you'll see the white thermal fuse,read it out,if that's good then you gotta make sure you're getting power to the ignitor,and read out the ignitor,the sensor and the gas coils,hope this helps,you don't have a heater relay on this model
Posted on Jan 10, 2010
  • 1314 Answers
SOURCE: Kenmore Gas Dryer
replace the selonoids
Posted on Dec 30, 2007
FixinFax
  • 3085 Answers
SOURCE: I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Posted on Oct 25, 2009
  • 2251 Answers
SOURCE: I have a Kenmore gas dryer Model # 110.76962501
if the ignitor was glowing you could have bad gas coils or a bad gas valve.check the coils with a meter to make sure they are good,also when you read out all the other parts did you remove at least one of the wires from the part,if not you'll get false readings.if the coils are good make sure the wires are pushed on tightly and check the metal connectors inside the plastic wire connector that slides onto the coils,i've found some that were messed up and not making a connection with the coil.also on one of the coils there's a metal sleeve, i think it's the coil with three prongs on it,check the old coil to see if it's stuck inside the old coil,if it is stick a screw driver in it,push it out and slide it back on the post and slide the coil back on the post,if everything checks ok you could have a bad gas valve,try wacking it with something to see if it will let the gas through.let me know what you find with the meter and how you make out,
Posted on Apr 10, 2010
Testimonial: "Thanks again. I had cracked by igniter while replacing last night. Now works fine."
richroth
  • 9472 Answers
SOURCE: kenmore elite nat gas dryer 75962 replaced ignitor
Here is a video to walk you thru the troubleshooting process.
Posted on Jan 06, 2011
My dryer stoped heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 17, 2011 | Dryers
Dryer stoped "heating up" the
heatman101
Dec 27, 2010 | Dryers
Its a gas dryer. Starts up but no heat. Ignitor doesnt glow therefore no flame. Checked with ohm meter , seems good . Also checked coils for gas valve,checked out good . When you start up there is no power...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Gas valves works off of amps pulled by the ignitor...ohms doesn't matter..
heatman101
Sep 06, 2010 | Dryers
Dryer wont dry
DOES THE IGNITOR GLOWS AT ALL?
IF U LOOK TRU THE FRONT CAP ON THE DRYER DO YOU SEE A GLOW ON THE IGNITER AN THEN THE FLAME?
IF YOU SEE THE FLAME HOW LONG DOES IT LAST FOR?
LET ME KNOW OR SEND ME AN EMAIL.
FASTNHONDA@YAHOO.CA
Feb 01, 2010 | Kenmore 73952 Gas Dryer
Ignitor does not glow
the flame sensor rarely goes bad
if the ignitor is not glowing
then thats the problem
take an amp reading it shoud be between
2.7 and 3.6 out of that range it will not glow
if your not getting a reading you need to chase your voltage l1 is you most likely culprit
Oct 03, 2009 | Whirlpool LGR3624JQ Gas Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
No heat it starts but the igniter doesnt light the gas
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jun 02, 2009 | Dryers
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Kenmore Elite HE4 Electric Dryer Logo
491 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
