Question about Dell Dimension 4600 PC Desktop
Keyboard plug in the pc is not working and and the keyboard is good
    Guru:
  • 571 Answers
Try using a different outlet/keyboard port in your PC. are you using a USB keyboard?
Posted on Dec 05, 2012
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
My keyboard is locked how do i unlock it?
Maybe you keyboard is bad or your keyboard has been hijacked by a virus.
Make sure you keyboard is plugged in good on the back of the computer. If the end of your keyboard that plugs into the computer is Round and it plugs into the green port on the back of the computer you have a PS2 (serial) type of keyboard and you cannot unplug it and expect it to work if windows has already booted up. If you remove this type of keyboard connection, you have to Reboot your machine otherwise the keyboard is locked.
If the end of your keyboard that plugs into the computer is Flat, then you have a USB type of keyboard that goes into the computer's USB Port. This type of keyboard is Plug and Play so you don't have to reboot if you remove it. If you have this type maybe the USB Port you plugged it into does not work, so try plugging into another USB Port.
Try booting in Safe Mode and see if the keyboard performs.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | Acer Computer Aspire AM3800-U3802A Desktop...
Keyboard locked
Apr 09, 2012 | Acer Aspire Z5700 PC Desktop
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
HI there! Keyboard is not detecting. It was working fine and suddenly it stop functioning. how to fix the problem.
remove and shut down the PC then restart with the keyboard plugged into the PC. It this wont detect then it is possible that the subprocessor in the keyboard has failed,
it will be cheaper to replace the keyboard than to have the IC changed unless one is around cheaper.
Sep 28, 2010 | HP D8597A Keyboard
Keyboard will not work. I shut off computer and removed mouse and keyboard and turned back on replacing the mouse and then the keyboard. Computer beeps (acknowledging the keyboard) but I can not type?...
If the keyboard is USB, and I am assuming it is, try plugging it into a different USB port and allow a minute for the drivers to install automatically.
If the keyboard is PS2 (round purple connector), make sure you have it plugged in BEFORE you turn the computer on, or it won't work.
If neither of these work, try a different keyboard; if that works, the keyboard needs to go.
Jul 01, 2010 | Dell OptiPlex 760 MT Desktop Computer
Keyboard wont work letters will not work and some come on double
Well there are two things you can test before replacing the keyboard entirely. First thing is if you have a usb keyboard try plugging that in and see if problem repeats itself on that keyboard, second thing is try turning off the computer and reseating the keyboard and see if it repeats the problem. If you have to replace the keyboard, might i suggest the warranty first, asus normally has a pretty good warranty, then try a good shopping search to find replacement.
Oct 29, 2009 | ASUS Eee 4G Notebook
My keyboard will not type!
This seems to always work for me as my Logitech does this too. I plug in the wired keyboard & use it for about 2 hours, then I turn off the PC & plug in the Logitech again and it usually works. I can't explain why this works but I'm always happy when it does. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200 Laser...
My son has an HP G6062 laptop with Vista and he cannot use the keyboard to access Windows.
if you can get into the bios settings using the keyboard but when it get to the windows logon screen the keyboard stops working then it could be driver issue within windows.
Get hold of a usb keyboard, and plug it in to the laptop with the power off, start the pc, if the usb controllers are enabled in the bios you should be able to use the other keyboard until you work out what the problem is with the laptop keyboard
good luck
Nov 15, 2008 | HP Computers & Internet
Keyboard LX501 keys wont work
Sounds like the Mac reconfigured your keyboard. Try a keyboard reset method like this one: https://www.wikihow.com/Reset-a-Keyboard
If no luck google "reset external keyboard".
Nov 09, 2017 | Logitech LX501 9674190403 Keyboard
Dell Dimension 4600 PC Desktop Logo
44 people viewed this question
Alun Cox
