Question about Exercise & Fitness
Owner's manual for Sportcraft 7.0 Pro treadmill
Need owner's manual
mattofilms
  • 110 Answers
SOURCE: Looking for a copy of the owner's manual for the Pro-form XP542E
Yes pdf file is free to view / download.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?lan=DUTCH&match=exact&name=295253
Posted on Jul 03, 2009
SOURCE: Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Posted on Aug 05, 2009
SOURCE: need owners manual for pro form 760 ekg treadmill
Email me at bwatts@netcomm-1.com and I'll send you a PDF file of the manual.
Posted on Feb 03, 2010
SOURCE: My Sportcraft Treadmill has an error code 7 and
Try this website http://www.howtomendit.com/answers.php?id=102798. It got mine running. I haven't had time to test it to see if it is a permanent fix, but it's running...
Posted on Mar 21, 2010
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
Need owner's manual for sportcraft TX 5.0 treadmill
Try Google with model number make serial number ,they may be able to help.
Jul 20, 2014 | Exercise & Fitness
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
I have a sportcraft tx 2.5 and was cleaning it and some water got into the housing where the motor and circuit board is located. Now all I get is the number 7 on the display and it won't run.
Dear Sir:
1) Please unplug the machine
2) Put with air gum machine, and pass in all board and circuit for heating.NOT OVERHEATING.
3) Wait for 24 hours. if you have some infrared lamps, will be better.NOT OVER EXPOSED.
4) Turn ON the machine, and proof, if the problem remain, the board is faulty. and replace.
5) However try to RUN the software calibration for better diagnose, troubleshooting, and fix it. see the block diagram attached.
God bless you
Jun 09, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
I need a Sportcraft tx 4.9 treadmill Manual.
Dear Sir:
go to download free www. fitness.manualsonline.com or www. retrevo.com or www.iconservice.com
God bless you
May 14, 2012 | Sportcraft Exercise & Fitness
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 31, 2010 | Exercise & Fitness
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Feb 25, 2010 | Exercise & Fitness
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
