We have a GE Zoneline Heat / Cool Model 2800 (with Heat Pump Model 3800). The blower works but no heat. The A/C works fine. My brother works for Marcone Appliance parts. He removed the housing to the control board, and suddenly the heat started working. It stopping the next day. We replace the control board, but no go...it still won't heat. What could be the problem?
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
SOURCE: GE zoneline heat not working
Is it not heating in heat pump mode, emergency heat mode, or both? The default heat mode on the AZ55 is heat pump. Does the fan blow in heat mode? It's difficult to diagnose a heat pump with the information given. Since you say the unit cools, it's not a compressor problem. Possible problems could be reversing valve, thermostat, control board, or switch, if it is in heat pump mode. If it is running in emergency heat mode, problem could be switch, thermostat, control board, or heating element.
To determine if the unit is in HP or emergency heat mode, have a qualified technician check the auxiliary control switches. There are 2 sets of these. The set on the left, switch marked ALL I2R. If it is down, the unit is in HP mode, up is resistance heat. Hope this helps some.
PTAC Dude
GE Zoneline Specialist
Posted on Nov 11, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Posted on May 14, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: GE Zoneline 1000 - heat stopped working this
Sorry to read about your problem, I hope this helps you out.
Sounds like you may a defective, reverse heat pump switch. If you were in Denver,Co I would be glad to work on it for you. They are no different than large units to work on.
and no, you cant work on the unit.....takes special tools
Just keep calling around for a person who will work on the unit..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
SOURCE: i have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
Posted on May 17, 2011
Flashes code ch09
check the control board. Make sure all plug ins are seated good if not seat them. If not I bet its your board.
Sep 02, 2014 | GE Zoneline In Wall Ptac Heat Pump Ac Air...
What are the setings for the dip switches model az28e12dabm3
We have the 2800 series manual posted online. You can get it at our GE Zoneline page.
http://www.airdistributors.com/userfiles/file/zoneline_2800_AE_manual.pdf
Generally, the default settings work best, unless you want to set temperature limiting.
Aug 15, 2014 | GE Zoneline Deluxe Series Cooling &...
Cool button on but computer thinks its on heat. It starts to generate heat when placed on a cooler level. Cant get the air conditioner to kick in.
If this is a heat pump unit, there is probably a problem with the four way reversing valve or its solenoid sticking in the heat position.
Aug 28, 2013 | GE Zoneline AZ55H07D Air Conditioner
GE Zoneline 1000 - heat stopped working this morning, A/C is working fine, fan is working fine, buzz sound when heat is turned on as normal, thermostat seems fine as room is still warm, can turn thermostat...
3 Thumbs - Helpful
Dec 27, 2010 | GE Zoneline AZ25E12D3B Air Conditioner
Dec 14, 2008 | GE Zoneline AZ55H07D Air Conditioner
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Jan 24, 2008 | GE Built-In Room Air Heat Cool Air...
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
