FixYa.com
Tags:
ASUS WL-330G 802.11g/b  Wireless Access Point
Limited or No Connectivity
posted by erinrox on Jun 09, 2007
Yesterday I could not receive any signal from my WL-330g. I tried to reset the router and the modem, then it worked for a while but the connection was really slow. So I restarted the computer but after that, it says no connectivity or limited connection. The ASUS Utility is saying that there is no connection and I should check my network connection.
I tried to check the listed available MACs on my router setting but the ASUS wont show. The other pcs with other wireless connection are working fine and can be detected.
Is my WL-330g broken? Can Ethernet Adapters be fixed? And can somebody tell me what caused this problem?
Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 19, 2007
Helpful (85)
alex8642
Rank:Master Master
Rating: 84%, 17 votes
are you running windows xp or vista? if so make sure that your DHCP service is running, and also make sure your IP address is configured to "obtain automatically" if your router is configured to do just that. Otherwise I would say:
1 - upgrade firmware
2 - make sure everything is configured correctly on router and pc (I suggest making same as other computers connected)
3 - uninstall and reinstall your network adapter or install newer drivers for network adapter.
4 - your router is bogged down due to the fact there is more than one computer connecting to it. It may not be built to work well with more than 1 pc, even though it is capable.
5 - your router is not within good strength connection of your pc.
- i can help you more if you give me more information and try the things listed above. but be careful when screwing around on the router settings, you could click something causing everything to stop working.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 10, 2007
Not Rated (0)
razorbackfan
Rank:Guide Guide
Rating: 82%, 7 votes
Yes, the wireless adapter can be fixed, by replacing the motherboard.
Can you Help with these Wireless Access Points problems?
Radius Server Work Around
Hello, we currently have a... Answer This...
How do I connect 3 wireless...
I have 3 wireless routers... Answer This...
REset button on WH-5400 CPE
Hi I have the same problem as... Answer This...
sierra aircard 875u connect to...
Hi, I have a sierra aircard and... Answer This...
Wirless Router with Du...
I Have Du Connection in Dubai... Answer This...
Repair Service
Find Wireless Acc. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
