Question about Whirlpool LER5636P Electric Dryer
Dryer motor/heat does not start
The electronic panel indicated the cycle & time etc. ... when you select Start, you only get a "click" from the panel. The motor does not turn, hum or make any sounds. The heating does not work either.
It is a Whirlpool Calypso Dryer, GEW9868KL0
Thanks, D
  • 1 more comment
  • drewhall Jan 17, 2009
    Anyone willing to look into this?
    Replaced the thermostats (both) and checked continuity of the coil, all OK.
    Electronic panel still working but motor and coil do not engage after start is selected. I suspect there is another thermo switch for the motor?....
    OK, for wayone else having a similar problem, you can save some money.
    In the case of motor not turning, it was the Thermal Fuse. $10 part located in the blower housing, very, very easy to replace.
    Great web site called eserviceinfo.com that has most schematics and manuals you need to fix almost anything and they are free to download. If you have any interesting manuals you can also upload them there to share with other.
    Second place to look is the Thermal Cut-off, also very easy to get at and about $50 for a kit. Problem in this area is identified by the fact the motor turns but no heat.
    D
  • 979 Answers
This may sound dumb, but it happened to me once. I turned off the breakers, then turned them back on and it worked. Sounds like you have done all the other stuff. The last thing that the other fellow put on the site, makes sense as well. Check the breaker first and the connections.
Posted on Jan 17, 2009
Electronic panel freezes!
In reference to Kenmore washers in general:
Most washer's can be reset like a personal computer.
If the appliance does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the appliance, that requires service
Jan 23, 2018 | Kenmore Washing Machines
Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Jul 14, 2008 | Maytag MED9600S Electric Dryer
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool LER5636P Electric Dryer Logo
193 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
