Question about Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 will not come on
When I plug my Canon Elura 100 camcorder in to the AC adapter, the screen comes on showing a blue "Canon" logo, and I hear the little "ping" sound that it makes when it powers up. However, this happens even if the power switch is turned to "off", and turning the switch to "camera" or "play" does nothing--the screen still shows the "Canon" logo. The only way to turn the unit off is to unplug it from the AC adapter and wait for the battery to run out.
I am able to load and eject tapes, but I can't record or play back on tapes or SD cards since the screen never shows anything but the "Canon" logo.
  • up_to_eleven Jan 12, 2009
    How do I check the signal from the AC adapter?
    Ok, I think I have an old VOM somewhere, I will try to check the AC output.
  • Canon Master
  • 13,433 Answers
This camcorder should have a removeable battery you can take out.
Remove the battery and the ac adapter, wait 5 minutes and plugin the battery again, if you have the same problem and the camcorder is still stuck on the canon screen, the internal software is most likely corrupt or you have a hardware fault.
All I can suggest is to send it to canon repairs
http://www.usa.canon.com/consumer/controller?act=OnlineRepairBookingAct&fcategoryid=227&modelid=12827
Posted on Jan 12, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Ok- To Eliminate the Stress and Hassle of Busting into the Ac Adapter. Simply get a New AC Adapter. The Problem lies Therein and should Fix your Problem. Let me know what you get Please!
    Top Expert:
  • Canon Master
  • 77,169 Answers
Check verify the voltage output of the AC adapter, is it a clean DC signal?
  • yadayada
    yadayada Jan 12, 2009
    if the ac adapter is not working correctly then u will havwe this issue, have u checked it, if not why poor rating, oh well good luck.
    To check u need a DVOM meter from any Radio Shack, they will show u how to use it.
Grey bars show across the screen image during playbvack and download with my Canon Elura 100 digital camcorder.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 24, 2011 | Canon Elura 100 Mini DV Digital Camcorder
I am using an old, borrowed Canon NTSC Elura 100 camcorder with a Mini DV 60 tape. I do not have the original Picture Package software or the manual, and I am trying to transfer onto my computer, which...
You can download the manual, software, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/elura_100
Dec 12, 2010 | Canon Elura 100 Mini DV Digital Camcorder
I have a Canon elura 100 camcorder miniDV it has was everyone tells me is a firewire cable to connect to my pc. I have several pc and laptops but not one has a connection to connect this cable to them. ...
Most Windows PCs have USB ports, but no Firewire port. As they do not come with this interface, you need to fit an add-on Firewire interface card into one of the PCI bus expansion slots. You can buy these cards cheaply from eBay or Amazon. They will come with a driver for the card.
Of course, this only works with desktop computers, laptops or notebooks cannot be expanded in this way.
Nov 24, 2010 | Canon Elura 100 Mini DV Digital Camcorder
I have a Canon elura 100 just has blue screen and says Canon. It powers up but everything else is useless other then seeing the blue screen that says cannon on it.
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Aug 27, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Nov 12, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Won't play tapes, just stays on the blue screen
ok. what you need to do it hit the side where the tape goes in...start out slow and then gradually hit harder and harder...not too hard though...because it sounds like a hardware jam...you need to unjam it by shaking it up a bit.
Jun 28, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Camera won't record
Hi!
First of all, English is not my natural language, so please forgive me. My canon elura 100, bought in the US 1 year ago, had the same problem. After a big fall (from a second floor), the camera landed in wet sand and after that the camera won't record again (it plays the recorded files just ok). Just today i had the time to check the camera, so i disassemble the camera and found a poorly connected cable, that goes from from the lens body to the motherboard of the camera. After reconnecting this cable the camera start recording again.
regards
May 18, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Downloading my camcorder
See to it that you have an OS which is XP version or Vista Version. then Plug your camcorder, if it detects low power transfer the connection at the back of your PC, then double click you my computer icon see if another drive come out, if it has then thats it, double click the new drive then locate all your files then copy and paste it unto your PC.  if still didn't work out I'm sure it has a CD suite then install it. Thats it..
Mar 23, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 Power Dead
Just an update.
I sent it back to the factory - and they fixed the power unit.
However, they told me that now my Memory card and memory card operations will not work.
They did not charge me for it - they took it under warranty.
Everything else seems to be working.
Oct 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
50 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
