Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Does the hitachi ultravision have a audio output
2 Suggested Answers
bernardlunda
  • 318 Answers
SOURCE: I have no audio on the HD stations with my Hitachi
Check if the audio output on A/V pins have a fine sound output on the audio pins, using a headset. if you dont hear a fent sound from the pin sound coming from the pre amp, then take your tv for a replacement of an audio ic output power amplifier.
thanks.
Posted on Feb 12, 2010
P50s601 sound issue
The model number indicates a Hitachi Plasma (correct?)
If buzz etc one channel is having a problem (not likely the speaker as you have discovered)
RCA HAS A OLDER SET WITH SAME MODEL NUMBER.
Means the left channel in the audio output is defective--If you Google the model number with "service manual" you should be able to find a schematic which will tell you if a single chip is used for both channels for output (this is usual case).
With that information either the chip or the board it is located on should be able to be repaired or replaced outright.
PTS ELECTRONICS DOES REPAIR BOARDS WITH ISSUES LIKE THIS (national company) in case you cannot locate either the part or the complete board.
Hitachi customer service may also be of help if you contact them--one channel low, buzz etc almost always is in output circuit of the audio.
Mar 26, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
Cant get sound from the cable box but I get when I play the DVD system
make sure you have audio rca cords running from the cable box to the television. Those are the white and red cords. They should be going from the audio output on the cablebox to the audio input on the t.v.
Jul 26, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
I have a hitachi ultravision 53in fdx01b im experiencing a blue doublevision please help.......
sounds like the convergence circuit has decided to quit working..  hitachi uses convergence output i.c.'s for this in the circuit.  one is probably bad.  suggest replacing both though..
Jul 30, 2010 | Hitachi 53FDX01B 53" Rear Projection...
We have no sound on the TV but we do with the WII
it could be the output on cable box or input audio or cable
Apr 13, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I have no audio on the HD stations with my Hitachi Ultravision television. My Sony flatscreen in another room works fine.
thanks.
Sep 23, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
No sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 06, 2017 | Hitachi UltraVision CineForm 55VG825 55"...
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
I have a Hitachi Ultravision projetion tv
One of your convergence output IC's has burned out and needs to be replaced.
Apr 24, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
