Question about Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord
Saw quit I used my saw 1 day then took it out of the box the next day and nothing. Power cord is fine and with a meter the power goes thru the trigger. Brushes look fine . It is 10 -15 yrs old but has never been burnt.
This was helpful in solving the problem with my Sawzall. However... the pins that had moved where the pins in the receptacle on the saw. They had pushed back into the female portion of the connection. I pulled that back out with a pair of needle nose pliers and viola! Shees-a-workin! Thanks! Greg.
Posted on Jun 17, 2009
  • 2,176 Answers
OK there are quite a few things to look for. It seems that you are comfortable with some disassembly so lets go further. I dont know what model you have but it still might have a broken wire or the pins pulled out of the plug end. Look at that first. If you have power thru the switch I would next check the field and while there look at the "flag" terminals that go to the brush tubes, they had a habit of coming loose and stopping the tool. If this is the case you can remove the brushes and after pushing them back solder them to the brass tubes. Lastly roll the armature by hand and look for any serious discoloration or differences on the commutator. Let me know if I can help more.
Posted on Jan 13, 2009
Skill saw table saw model 3400.Bypassed on off switch still no power?Does motor have a breaker on inside?
I have the same saw.
Sorry but this question has to be asked, is the AC (Alternating Current) outlet working/ an live outlet? Had to ask.
If outlet is good move on to the next steps.
Take an ohm meter / continuity meter.
With the AC power cord unplugged from the AC wall outlet.
Place the two test leads from the meter onto the plug prongs .
With the switched closed/ON, you should get zero ohms (or very low, close to zero/ continuity).
In your case you probably will not have any continuity because it doesn't turn on.
Now comes the fun part trying to find the problem/ open connection.
Lots of possibilities.
  1. The AC cord could be bad at the plug end.
  2. The AC cord could be bad at the point entering the table saw.
  3. The motor could be bad.
  4. The brushes in the motor could be bad.
  5. The field winding in the motor could be open/bad.
The plan is to ohm/continuity check the path of the power going to the motor, (both sides of wiring).
While meter leads are on the AC plug end, wiggle the strain relief ends. You have an intermittent connection.
TROUBLE: SAW WILL NOT START
PROBLEM 1. Power cord is not plugged in.
2. Fuse or circuit breaker tripped.
3. Cord damaged.
4. Burned out switch.
REMEDY 1. Plug saw in.
2. Replace fuse or reset tripped circuit breaker.
3. Have cord replaced by an Authorized Skil Service Center or Service Station.
4. Have switch replaced by an Authorized Skil Service Center or Service Station.
May 25, 2016 | Saws
I have to replace the power switch on my Delta Shopmaster 10" radial arm saw. I have the switch, which is a Delta 438010170206S Rocker Switch has (4) terminals. I need to know which wire goes where????
How many wires do you have? The switch is probably a 2 pole, On-Off. If you have 2 wires, connect them to two terminals on one side of the switch (use an ohm-meter to find which terminals make-break). If there are 4 wires, connect the black and white power cord wires to different sides of the switch. Then connect the two motor wires to the two remaining terminals. DO NOT CONNECT THE BLACK AND WHITE POWER WIRES TO THE MAKE-BREAK TERMINALS OF THE SWITCH. This creates a short in the power cord and will trip a breaker.
Oct 29, 2013 | Delta 10" Shopmaster Radial Arm Saw 1-1/2...
Viewsonic n3260w will not turn on no green light and I have check the plug ,cord and power at the wall
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | ViewSonic NextVision N3260W 32 in....
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have no power to saw. I have checked the switch and still no power. Is it possible that the power cord could be bad? Is there something else I should try?
if you have a volt/ohms meter remove the handle half to expose the wiring and unplug tool test the cord by itself and if ok continue on thru the brush holders.
Jan 09, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Heater was working one evening the next day it doesn't turn on there is power to the heater because the night light is working.
Well, let's develop some trouble shooting skills:
Do you have a continuity checker? Called an Ohm meter, or a Multi-tester)
Some possibilities: a loose wire at the plug, or the inside connections in the unit.
Can you unplug the unit, from the wall plug, and open the covers, and do some checking for us?
Check continuity from each side of the power plug, to the corresponding wires in the control box inside the heater-- can you get continuity-- even while wiggling the cord?
How about thru the switch?-- and how about thru the heater element?
Tell us what you find, and we'll help you get to the next step.
Mack B
Dec 28, 2010 | Presto HeatDish Compact Heater
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Printer wont turn on
change the power cord and see. bye
Sep 26, 2007 | Lexmark Z640 InkJet Printer
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord Logo
345 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
