When can i open my computer there a problems, the screen were dispay the bad signal? what will ido
    Sergeant:
    Champion:
  • 267 Answers
CHECK YOUR ANTENNA/CABLE INPUT ALSO SEE IF UNIT WORKS WITH DVD ON A VIDEO INPUT. USUALLY IF A MESSAGE OF BAD SIGNAL COMES UP, THE SIGNAL INTO THE RF CONNECTOR IS TOO WEAK OR MISSING.CHECK THE CENTER WIRE OF THE CABLE THAT PLUGS INTO THE TV.
Posted on Jan 12, 2009
Rca no signal
check thet rca video is on the video port and rca sound on the sound port alternatively choose screen mode with remote
Jul 16, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
Packard bell new90 no signal on vga output
Right click on your desktop and select Screen Resolution. Then change it from Extend to Mirror.
Mar 07, 2013 | Computers & Internet
DVD player keeps searching for signal during movies
seems it is lens problem, change the lens from a reputed wervicing
Jun 23, 2012 | Samsung Audio Players & Recorders
I have 1978, 22' ford brougham motorhome,i'm haven problems with the turnsignals not working, i have emergince flashers, ihave changed th flasher for the turn signals, and cheked all the wiring, ido have...
if have checked power at the receptacles where the bulbs plug in then I would say the bulbs are bad, but if you have no power then I would say there is a bad ground. Hope this helps Tim
Sep 01, 2010 | Ford Econoline Wagon Cars & Trucks
Dell monitor S199WFP....the blue power light stays on....the screen goes black after a few seconds. I've checked the power cord and the cord connecting the monitor and computer. Do I just need to get a new...
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Jun 18, 2010 | Dell S199WFP 19" Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Display skips, blinks and pauses
The Hdmi cable is either loose or your ps3 dispay settings are wrong
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Blank screen
hi i am kishan, from india u r facing this problem so same problem is facing my customer so i think its problem of your lcd so u can do one thing \ back side of your laptop u will find vga port so do arrang one moniter(desktop) and attach it to your laptop vga port and then start your laptop and press alt+f5(simbol of external monitor) and u can dispay your windows on moniter now u can take your backup it will work but u shoud check your laptops lcd dispay regard .... take care
Jan 20, 2007 | Compaq Armada E500 Notebook
No display
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Mar 18, 2006 | Neovo E-19A 19" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
