Question about Samsung UN46D7000LF 3D TV
UN46D7000LF Try to turn the TV on, and now it just tries to start and then turns off and then tries to start again and then turns off again and keeps going through this same cycle. I have to unplug from the power outlet to get it to stop.
  • 4 Answers
SOURCE: my samsung 40" lcd power problem
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
  • 210 Answers
SOURCE: My Samsung LCD tv clicks over and over again but won't power on
this is common fault the capacitors have blown on main power board you can replace your self if got soldering iron
take back off tv and look for capacitors that have RAISED TOPS they look like little batteries with white line on one side and numbers (e.g 2000mf 25v ) the best way to remember which way they go back is take picture
you can get parts from charles hyde and sons web site (CHS) under general components or at a electronic shop
Posted on Dec 14, 2009
eagle338
  • 4889 Answers
SOURCE: Samsung LN46A550 LCD power on/off problem again.
It is the Main A/V board that is faulty, not the power supply. The rainbow screen that you are seeing and the searching for signal message before it shuts off confirms this. It is the large board at the center of the tv. If you can get me the part number off it, I can find you the replacement. It will be either printed on the board itself or on a small label.
Sai.
Posted on Feb 05, 2011
SOURCE: my Samsung flat screen tv won't turn on and it
There's a couple transistors on the Power Supply board that are probably bad. On mine, the solder joint was bad on the bottom side of the board that pointed me at those transistors in particular. Part number is FQPF9N50C. Also, you could get a refurb or new power supply board of ebay or send your board in for service (also on ebay).Or there's a "repair kit" you can get that contains 4 transistors and a couple caps I think. If you are an electronics junky and like soldering stuff, that would be the way to go... I just ordered the two transistors off ebay for like $6.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320632712822
http://cgi.ebay.com/Samsung-HP-T4254-Internal-Replacement-Circuit-Board-/230575679230?pt=LH_DefaultDomain_0&hash=item35af61a6fe
http://cgi.ebay.com/REBUILD-YOUR-SAMSUNG-BN44-00161A-Power-Supply-/200513469692?pt=LH_DefaultDomain_0&hash=item2eaf88bcfc
  • 8457 Answers
Yes,T-Con board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Posted on Feb 06, 2011
Samsung UN46D7000 tv still isn't turning on. I've already replaced the power board (I think the original was fried in a power surge).There's no standby light either.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2017 | Samsung UN46D7000LF 3D TV
Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Jun 28, 2014 | Jensen Televison & Video
The menu options keep poping up
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
Mar 09, 2014 | Televison & Video
Problem with lamp turning on
maybe try turning off at wall rebooting device can harm the computer if you turn off both you may turn off modem box thingie
Nov 21, 2013 | Panasonic PT-50LC13 50" Rear Projection...
Tv keeps turning off after turning it on.
Based on the lower specification of this TV any repair is more than likely going to exceed the cost to replace it, One of the internal components has failed and generally unless you are handy with an oscilloscope it's not worth fixing.
May 04, 2017 | LG Electronics - 32LS3400 - 32 Led 720p...
Getting rid of subtitles on samsung smart tv
There should be a button on the remote control to turn on and off the subtitles. On three of my Samsung products the subtitle button is marked as "subtitle"
Best Regards,
Mar 31, 2012 | Samsung UN46D7000LF 3D TV
I am trying to auto search my urc-4700boo remote to a emerson tv i went through all the 4 digit codes already and it didnt work so i want to try to do it on auto search but need the instructions on how to...
TRY THIS...TURN YOUR TV ON...THEN JUST KEEP PRESSING THE POWER BUTTON ON YOUR REMOTE, TILL YOUR TV TURNS OFF, YOU WILL NEED TO DO THIS AGAIN TO TURN YOUR TV BACK ON.
THIS WILL SET YOUR REMOTE...IF IT DOESN'T...THEN, START AT 01 ENTER, 02, 03 ,04 ETC,.
THE FIRST SUGGESTION IS THE BEST!
HOPE THIS HELPS!
Sep 03, 2011 | Televison & Video
My 32LG350 wont turn on. I just pluged it for the first time i bought it like a month ago. it was working but suddenly it turned off by itself and wont turn on either by pushing the TV on/off boton neither...
Try unplugging the the TV from the power outlet for 30 seconds to a minute and plug back in again. Try to turn on again. Some TV's have to be in a "ready mode" to operate by remote - so besure it is in that mode - or use the power button on the TV.
Apr 01, 2011 | LG 32LD350 32 in. LCD TV
I have a wireless network in my home. I just ordered a SAMSUNG UN46D7000LF 46inch TV. The TV is wifi capable. When my TV arrives, can I just turn it on and set it to wireless network and it will find my...
If you have a wireless network, and the TV is wireless, then there will be no need to get extra cables for the TV. I'm sure if you read the book or even look at the menu observantly you will have that beast up and surfing the net in no time flat.
Mar 24, 2011 | Samsung Televison & Video
My 52 in jvc model lt-52x579 turns on but there is no picture or sound and about two seconds later the led light for the power starts to blink i tried to turn it off but it just keeps on trying to turn on...
Sound like the power supply board has gone out .Unplug the tv for 2 or 3 minutes and plug it in again and try to turn on. Some times they will come on .But It sounds like the PSB is going out .
Feb 14, 2011 | JVC LT-52X579 52 in. LCD TV
Samsung UN46D7000LF 3D TV Logo
116 people viewed this question
Henry  Thomas
Henry Thomas
