Question about Nokia N900 Smartphone
Nokia n900 will not turn on
I was using my phone and it suddenly died and would not restart it was charging at the time and had at least two thirds of battery life. It was raining but I don't think it shorted out. If anyone as a solution it would be much appreciated.
    Master:
  • 368 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Dec 05, 2012
  • 311 Answers
SOURCE: my nokia 5630 Xpress Music battery life is very
change your battery and format your phone
Posted on Dec 17, 2009
SOURCE: Nokia 5130 and I forgot my security code. The
i want remove my security code but i forgot my secrity code tell me how................. i remove my nokia 5130 xpress series password
Posted on Dec 23, 2009
abrahambaby
  • 182 Answers
SOURCE: my nokia n95 wont turn on even when charger is in
better you go to nokia service center make a good check up or try by replacing with nokia s original battery and charge for it continusly for upto 6 hrous with out switch on the phone ..... try it
Posted on Feb 02, 2010
Clam_Chowder
  • 59 Answers
SOURCE: how to get serial no. for Nokia N900
Try typing this in to get the serial number:
*#0000#
Posted on Feb 27, 2010
  • 5 Answers
SOURCE: My Nokia N95 8Gb is dead now. It had turned off
just buy anew phone..
Posted on Mar 23, 2010
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
Nokia n900 unlok cod ime 356938/03/70088/8
I would suggest you some good ways to get the unlock code for Nokia N900 mobile by contacting the Network Service Provider. Normally they won't provide you the code until the contract period gets over. If you are in urgent need of getting the code, visit any third parties site. I too used the same mobile which is locked to O2 Network(Ireland). I got the unlock code from Theunlockarena.com . Here you can check for your service by specifying the details like country and network it is locked now. If the service is available, they would send you the code to unlock your mobile.
Apr 09, 2013 | Nokia N900 Smartphone
I have a nokia n900 and when I want to turn on the phone, it will not boot only be switched on and off (to restart)
Hello:
5.Wait 10 seconds.
Step
Thanks
Feb 10, 2013 | Nokia N900 Smartphone
How to unlock n900 from us to philippines
It simple to unlock the Phone from Network lock,you can get the Unlock code from the site
www.classicunlocking.com and UNLOCK it, you can follow the instructions below and unlock it step by step...
Nokia N900 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N900 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N900 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N900 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N900.
3 - Compose #pw+CODE+1#.
4 - The Nokia N900 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N900 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N900
Oct 13, 2011 | Nokia N900 Smartphone
My Nokia n900 is not charging fully especially using the wall socket charger, i love this phone only this problem. thanks!
Ifthe is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.If the battery drops to an unacceptable chargelevel then the battery needs to be replaced.
Jan 20, 2011 | Nokia N900 Smartphone
I forget my nokia n900 security code how can i reset it?
when i restart my nokia n900 its show us security code but i dont know what is the security code
Dec 15, 2010 | Nokia N900 Smartphone
The problem with my nokia n900 is when the battery finsh and the phone turn off icant charge my phone nokia n900 can you help mee plzzzzz
Remove and re-install the battery. Keep the phone switched off and connect the charger. Wait a few minutes before you attempt to switch it on again. If this does not work, your battery is fried due to deep discharge and needs to be replaced.
Update the Maemo 5 operating software on your phone, the current release removes a lot of software problems, including the charge blockade in low battery situation.
Dec 13, 2010 | Nokia N900 Smartphone
Restored the phone to a backup and it has just died on me. No reponse to trying to switch it on. Battery fully charged. Connected it to my computer and the computer does not acknowledge it is there.
For resolving your Nokia N900 problem, I recommend a firmware replacement to reinstall the system software. Full instructions and software are available here.
Your computer does not need to acknowledge that it is hooked up for the firmware update to be successful. Sounds funny, but trust me it does work.
I hope that helps.
Mar 08, 2010 | Nokia N900 Smartphone
Nokia N900  Smartphone Logo
144 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
