Question about Black & Decker B2300 Bread Machine
Bread is ****.
Am I supposed shape the dough in the breadmaker before it rises?
I am really confused with this thing.
The first loaf I made could have bricked my house (out of the manual).
The second loaf I made was higher but sank in the middle. Found it to be heavy in the stomach like cement (recipe on line).
The third loaf I made was higher on one side than the other and the top was not nice and smooth neither were the last 2 recipes. What am I doing wrong?
Desperate for fresh bread in Stratford.
  • gerame Jan 12, 2009
    I don't use bread mixes. Just the ingred. called for in the recipe.
    Flour/ White/Whole Wheat
    Dry active yeast
  • eparr Feb 04, 2009
    I follow the recipe exactly, the bread rises beautifully and when it starts to bake it sinks in the middle. I have tried the trouble shooting suggestions but nothing seems to help.
  • 2,976 Answers
Try to buy bread mixes that are in proportion to your machine. I had a machine that mads 2-1/2 pound loaves. I could only find mixes for 3/4 pound loaves. I had to buy multiple mixes, put them together and divide them by weight. I gave the machine away.
Posted on Jan 12, 2009
When I bake a loaf of bread it comes out of the machine with the ceramic mixing paddle baked into the loaf! How do I keep this from happening?
That often happens with bread machines. You can lessen the possibility by using milk in place of water and also choose light crust. This is pretty advanced but if it really bugs you,,, here goes.... After the final punch down and at the very beginning of the final "rise" stage you can remove the dough ball with one hand,( lightly flour your hands first) try to remove the paddle with the other hand from the dough ball and return the dough ball to the center of the pan, and close the lid Just be sure you don't remove your dough ball too early... check your owner manual and be sure you don't remove it BEFORE THE FINAL PUNCH DOWN....!
Feb 15, 2013 | Kitchen Appliances - Others
Bread kneader gets stuck in loaf
That is going to happen often with breadmachines, especially when making breads with thick crust. The only way to avoid it 100% of the time is to make dough with your machine and then do the final rising and baking in the oven. There is one other thing you can do to avoid the dreaded" paddle injury" to your loaves and still bake in your machine. Visit me at and I'll reveal my little trick!
Feb 06, 2013 | Kenwood Bread Machine BM350
When my machine goes into the next to the last rise I have a loaf about 5' but then when it goes into the last rise before it bakes it never rises high again. The finished loaf is about 3 1/2" high....
Not fully understanding this but it sounds like you are opening the lid too much and spoiling the rise. Only open the lid when at the dough stage if necessary.
Bread will not keep warm, it will steam and go wet and soft in the pan. Open the lid when the cycle has finished and remove the loaf.
Try re-setting your machine by holding down the start button till the display goes out.
Jan 28, 2011 | West Bend 41048 Bread & Dough Maker
WE only have a Silvercrest Breadmaker a few months now and the bread sticks to the Kneading Blades and as a result the bread becomes broken when taking it out of the tin, can you please help.
This is very easily fixed. In fact in the instruction manual it suggests you stop it before baking and remove the blades. After almost a year using it, we have further refined this. As soon as 2nd kneading is done, we pause it, remove the blades, oil up hands with olive oil, and shape it into an approximately cuboid shape, before putting it back in the tin and resuming the programme.
From the 2nd time we used it we did the removing the paddles, but with trial and error have found that shaping the bread means you get a much more even loaf, and later that oiling the hands to do this makes it rise much better, as it prevents the dough sticking to the sides, inhibiting the rise.
By the way, the programmes we use most are no. 8 (mostly), in which case you remove the paddles after 70 mins, and no. 2 (occasionally), where you do it after just after an hour.
Hope this helps, it's certainly made it work much better for us!
Nov 17, 2010 | Kitchen Appliances - Others
Crust is thick and hard, paddles tear large chunk from bottom of loaf when removed from pan.
unfortunately all bread machines leave the hole in the bottom where the paddle is. some machines leave a bigger hole than others, with the exception of the cuisinart cbk-200 which allows you to remove the dough, then remove the paddle, then reshape and replace the dough....One thing you can try to have a softer, lighter crust is to replace the water in your recipe with the same amount of milk. If the hole in the big hole in the loaf really bothers you I suppose you could remove the dough exactly at the end of the final knead, remove the paddle and replace the dough in the pan...I've never done it but I've certainly considered it! best wishes and happy breadmaking...
Nov 08, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Loafs dot look right
Black and Decker bread machines need a little more water in the dough, about two tablespoons for a two lb loaf. If the loaf does not rise enough, cut back on the salt about 1/4 teaspoon at a time, no less than one teaspoon for 2 lbs or the bread will be all full of large bubbles.
Here is my owner's manual:
Bread machine recipes
Mar 29, 2010 | Black & Decker Bread Machine
Chefmate bakery oven model cm 725
Since practically all bread machines work the same simple way, you don't need the manual if you read the excellent instructions at the following website. The following website tells you how to operate a bread machine, even if you don't have the manual. It also includes great recipes (and you can easily find many more recipes online). Using the following website, I was EASILY able to figure out how to use my Chefmate 725k bread machine even though I didn't have a manual.
By the way, the Chefmate 725k holds 16 cups of water which means that it should be able to make a 2.5 lb loaf of bread (though I've never tried to make a loaf that big). If I'm making one loaf of bread, baked in the machine, I'll generally make a 1.5lb loaf. But more often than not, I just use the bread machine to knead and raise 2 lbs of dough. Then I remove the dough (with rubber spatula) cut it into two equal parts, and then put the two pieces of dough into separate 5" x 8" x 2.5" bread pans (if I want a traditional shaped rectangular loaf of bread) or on a cookie sheets in round or oval shapes. I don't really care for the shape & style of bread that is baked in a bread machines.
Dec 05, 2008 | Chefmate TR 7000 Bread Maker
Bread falls while baking
Try using a little less yeast or slightly more flour. The dough is either not quite stiff enough or slightly too much yeast.
Jun 13, 2008 | Cuisinart CBK-200 Bread Maker
Bread too high
The one thing that rises bread is yeast. You have some super duper yeast if the breadmaker suggests a certain amount and you keep getting the same results. You can either reduce the rise time -- or the amount of yeast -- or both.
Jan 07, 2008 | Black & Decker B2000 Bread Maker
I have a problem with uneven shaped loaves
The paddles fit two ways, so what you must do is have them facing opposite ways, then they fight with each other and elongate the loaf
Dec 30, 2006 | Black & Decker B2000 Bread Maker
Black & Decker B2300 Bread Machine Logo
200 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
