Question about Jenn-Air JMV8000 Microwave Oven
Sharp microwave r-930cs won't heat popcorn - Jenn-Air JMV8000 Microwave Oven
3 Suggested Answers
De Engineer
  • 247 Answers
SOURCE: Sharp R-930CS Microwave
Check to see the turntable it is seated properly. Try to spin it by hand. If it moves easily, it is not in the right place.
If seating it properly does not solve the problem, you'll need to take it apart to see what the mechanical problem is caused by.
It could be as simple as a clogged gear. Or it could even be a broken gear or bad motor. A visual inspection should provide clues.
Be careful. Disconnect it from the AC before taking it apart and do not operate the microwave disassembled as microwaves are harmful to humans. It can cook them!
Posted on Mar 25, 2008
  • 686 Answers
SOURCE: Sharp Carousel R-930CS-F Wont heat
CHECK YOUR FUSES. IF GOOD IT MAY BE THE MAGNETRON IS BAD
Posted on Apr 17, 2009
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Sharp R-930CS microwave turntable stopped turning and neither convection or microwave are working (ie. not heating). Lights and fan turn on and counter counts down normally.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Oct 19, 2013 | Sharp Microwave Ovens
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
My microwave door sags to the right from the top hinge. The microwave is a Sharp R-930CS. How do I adjust this?
The only adjustment is by removing the outer cabinet and examining the hinge side will be self explanitary.
Beware that the door must close squarely and if it is very mal adjusted will take out the mains fuse!
Oct 19, 2010 | Sharp R930CS Microwave Oven
Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 04, 2010 | Sharp R-55TS Microwave Oven
Apr 17, 2009 | Jenn-Air JMV8000 Microwave Oven
Turn table has stopped working in sharp r-930cs
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Jenn-Air JMV8000 Microwave Oven Logo
41 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
