Question about Philips 6P5430W 54" Rear Projection Television
Orange /yellow picture
Ihave a 5yr old phillips 109cm rear projection which the picture has gone a yellowish /orange color. Ive been told that there is an oil inside that needs to be replaced. It is quite expensive to have it done proffessionaly as it is a slow tedious job. Have you got any info on how to do this myself to try and salvage this tele.
Thanks
  • mickysaad8 Jan 13, 2009
    All 3 color bulbs look like they are sending a strong bright color.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that you have two interrelated concerns: discoloration and coolant leak. The discoloration could have been caused by the coolant leaking into one of the small PCboards at the rear end of each tube. Often it would be on the blue tube but there are instances that it also happen on the green. For some reason, the red has very rare incidence of coolant leak. That being said, to address the coolant problem, some ideas you may want to consider/explore:
Procedures Changing Projection TV Coolant that you can try:
  1. Tip the TV set so the expansion chambers are pointed up. The expansion chamber is a small white/clear plastic bulb-like thing that is attached to one side of each of the CRT's up near the top lens. In some TVs, the expansion chambers are already pointed up - In this case you don't have to tip the TV
  2. Cover the circuit boards below the CRT's with several paper towels to prevent accidentally spilling any coolant onto the boards.The coolant is corrosive and will destroy the circuit boards. Don't skimp on the paper towels here - they are cheap!!!
  3. Remove the four screws that hold on the focusing lens assembly and remove the focusing lens assembly.
  4. Note the position of the expansion chamber then remove the expansion chamber. It will need to be reinstalled in basically the same position so remember the position or take a picture if you need to. There is a small o-ring on the neck of the expansion chamber where it threads onto the CRT housing - Don't loose it!
  5. Use the baster and tube to **** the fluid out from the hole where the expansion chamber was removed. This hole is fairly small...maybe 5/16" or so.
  6. Once most of the fluid is out, remove the four screws that hold on the lens cover plate.
  7. Remove the lens cover plate, the lens & the large o-ring. (be gentle with the o-rings!!!)
  8. Clean the CRT chamber & lens with denatured alcohol. Use 100% cotton balls so you don't scratch anything.
  9. Clean the CRT chamber and lens with distilled water. Again, use 100% cotton balls so you don't scratch anything. This will rinse out the alcohol residue. You need to use distilled water for this so there is no mineral residue.
  10. Gently clean the large o-ring with distilled water (don't use the alcohol because it might eat the o-ring) Dry off the o-ring and lightly coat it with 100% pure silicone (not siliconized acrylic caulking or acrylic latex caulking - ONLY USE 100% SILICONE).Use your fingers to rub a thin layer of silicone all over the surface of the o-ring. Then place the o-ring in the groove in the CRThousing.
  11. Place the lens in its position on the o-ring.
  12. Place the lens cover plate over the lens and install the four screws.
  13. Clean your baster and tubing with denatured alcohol then rinse with distilled water.
  14. Use the baster and tube to **** clean fluid from the bottle and install it into the CRT through the expansion chamber hole. Goreally slow when it is almost full to minimize overflow. Wipe up any overflow immediately. There will be a small air pocket inthe CRT when you are done - you will not be able to fill the chamber 100% - This is O.K. Just be sure to fill it as far as possible so the fluid is just up to the edge of the expansion chamber hole.
  15. Install the expansion chamber. Be sure to install it in the same position as it was before you removed it. Also be sure that the small o-ring is on the neck of the chamber before you thread it on. The chamber is just plastic so don't over-tighten it or you might damage it. Screw it on as tight as you can go by hand and then give it about 1/8 of a turn with pliers. (you might have to use needle-nose pliers to get a good grip on it.)
  16. Place the focusing lens assembly into position and install the four screws.
  17. Turn on the TV and check for leaks over the next 20 minutes. Remember, you have not yet removed all the paper towels from inside the TV. Remove these once you know there are no leaks.
You may also want to:
  • Clean the mirror
  • Clean the top lenses of the focusing assemblies
  • Focus the CRT's
  • Adjust the convergence
Good luck and Thank you for using FixYa.
Posted on Jan 13, 2009
    Sergeant:
  • 431 Answers
May i know the exat model no please
    Sniper:
  • 59 Answers
Hi this job is very hard to go and being that the tv is old the parts will cost alot i think it would be better to get a new tv because a new lcd tv will last you 100,000 hours so in the long run you wil save your self alot of money down the line cause there is a chance that something else will happen and it might cost more the next time around
Posted on Jan 12, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Since the Television is Older, Have you Checked the Color Bulbs to make sure that they are Sending the Correct Colors to the TV? Let me know so that we can go Further.
  • Travis Humphries
    Travis Humphries Jan 13, 2009
    Benimur has the Proper Solution to this Problem. He is Really good. Just follow his Directions for the Solution.
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Blue smears and dots on the screen and a orange yellow picture
Bad Light Engine/optical ASSY Encompass Parts Distribution 1-800-638-3328
Jun 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Slight yellow tint to the color.
replace the coolant in the picture tubes that will restore the color and the clarity. Heres a link to the kit which has the coolant and step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 24, 2009 | Philips 51PP9303H Rear Projection...
Adjusting to the proper color
Tint would be the control that will control the color balance, but this sounds like it may be deeper then that. Turn your color all the way down so that you have a black and whit picture. If the picture is still yellow then you have a problem with the blue picture tube.
Feb 02, 2009 | Philips 43PP9202 43" Rear Projection...
I have a phillips 60'' and has yellowish color around the edges
hi the problem the picture tube of ur tv has got repaired. pls rate me
Jan 18, 2009 | Philips 60PP9363 60" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
