Question about Lemax Toys
Sunburst Ferris wheel starts moving, then stops as if it was letting people on or off, but then a loud clicking noise begins and it won't move without a push. Continues to do this repeatedly. Don't want to burn motor up, what can we do to fix this?
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
bigg t
  • 640 Answers
SOURCE: Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Posted on Feb 22, 2008
  • 33 Answers
SOURCE: Kawasaki Ninja 4-Wheel
I have taken a lot of these power wheels apart, there are nylon gears that when the vehicle is powered forward and cannot move the teeth on the plastic gears will wear down and slip.
Here is an ebay site.
To replace the gearbox you will need to take off the axle cap and shaft washer that holds the wheel on.
Slide off the wheel.
I think this power wheel has a silver plastic housing that covers the gearboxes and axle, which means that there will be an amount of screws to take out before you can get to the guts.
Once you get to the wires on the motor you will need to cut and strip them and install the replacement
If you can, I would prefer you would crimp the wires together with a blue or Yellow **** splice, but if you do not have crimper or lugs You can use wire nuts large enough to firmly connect both wires. Then electrical tape the nuts and wires to prevent loosening by vibration. Even though these are 6 volt batteries their current is enough for wires not connected well to overheat, melt and could possibly become a fire hazard.
Ideally the wires from the replacement would be the same color as the original but if not you will want to test to see if while in forward it does go forward. If not you need to reverse the two wires. This is a headache saving measure.
Re-assemble everything making sure that the axle nut or cap goes back on Tightly to prevent the wheel from falling off during use.
Posted on Sep 27, 2008
SOURCE: Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
Posted on Apr 23, 2009
Chevy Blazer Humming Noise
are you sure its not a wheel bearing? does the noise change if you take a corner to the left or right?
Apr 30, 2013 | 1999 Chevrolet Blazer
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
Picture freezes while dvd player playing
The problem is in the laser pickup assembly, the stepper motor that moves the laser is sticking on the worm gear or excessive ware on the gear linkage is preventing it from moving.
Mar 14, 2012 | Samsung SWA-4000
HP DeskJet 970Cse cartridges won't move
okay be gentle, but try to move the cartridge box manually from side to side. it's possible that the gears have gotten stripped which is why they won't move even though they are trying to. so i'd try and move them from side to side and see if you can physically move it yourself. like i said be gentle in the chance the gear isn't stripped. good luck!
Feb 09, 2012 | HP DeskJet 970cse InkJet Printer
Wheel bearing is making noise when the car is moving
Is this noise a clicking sound ? If you steer to the right and it stops for a second or two then it should be the left wheel. If you steer to the left and the noise stops the it is the right wheel. Best way to know for sure is an automotive stethoscope. Best way to do this safely is at a garage. Don't let them try to sell you both hubs at the same time. The other one could go for years before it needs replacing.
Jul 16, 2011 | Ford Laser Cars & Trucks
2008 Toyota Yaris loud clicking noise only when making hard corners with the wheel fully turned right or left. The noise stops immediately as soon as I beginning pulling the car back to a straight...
This is the most common reason for the noise. It can be checked by removing the tire and trying to move the axle shaft. If there is play in the shaft it will be a good chance that the CV joint is bad. If there is no play, you can turn the wheel hub with the car still in the air and try to pin point the area the noise is coming from. Be careful and make sure the car is supported well before you try to move thins around too much. Cars will fall off the jack if they aren't supported.
Sep 23, 2010 | 2008 Toyota Yaris
Front wheels are locked loud noise
dear friend-it sounds like the drivetrain packed up,it is possibly the diff that broke and jammed the drivetrain.
Apr 23, 2009 | 1998 Dodge Grand Caravan
Loud cliunking noise in beginning of spin then won't spin
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Toys Logo
Top Lemax Toys Experts
ray gallant
Are you a Lemax Toy Expert? Answer questions, earn points and help others
