Question about Rowenta Effective DX1900 Iron with Auto Shut-off
Turns on, flashes yellow but never heats up
The yellow just keeps flashing but it never changes and never heats up.
    New Friend:
  • 18 Answers
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Just been through this with a Rowenta DM-890 for the second time.
Problem: as with many handheld tools the cord endures a lot of flexing and wires break at the flex point. The swivelling ball makes it look like this will never happen. Truth is, that the bending of wires occurs inside the handle.
First fix for us was a complete cord and sensor assembly
Cord/Power Supply - ( RS-UL4336 ) Fixed it the first time for about $35 for part.
Next break in cord; Tracked it down and shortened the cord, removing the break.
Last and most frustrating was " still no heating"
Open up again and found that I had not pushed the soleplate plug fully home 'til it snapped into place.
Result victory and very happy wife.
She loves this iron! I gather it does a dream job.
The cord will no doubt break again in about one year.
It's a tough fix for Rowenta designers ;
If they put sliding contacts in place of the swivel ball;
They would be faced with the contacts;
--getting wet while filling or fluid handling shocking hazard)
--getting dust and fluff in them (fire danger)
Only thing I can think of is a super flexible cord conductor material.
Repair advice: be aware of the point where the flexing of the conductors occurs and prepared to back in there again.
Update 2016-07-07;
The cord did indeed break again inside the handle just below the ball swivel point.
Solution for last year was to glue the swivelling ball so that the cord did not flex inside the handle.
The cord is stiffened outside the handle to keep it from flexing so much and it's hanging in there.
Posted on Oct 27, 2015
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
How do you test a pump on a tefal steam generater
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Irons
My iron lights up. when i set the heat choice the green lights on the right flash and it does not heat up
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
Apr 28, 2010 | Euro-Pro Shark GI490 Iron
Yellow light flashes, colored water leaks. Assume
If the water is reddish or black looking the iron insides may be rusted out, and is bad enough that the seal has been compromised. This happens if water is left in iron when storing. If the iron is still warrantied return it to the store where it was purchased, or buy a new one.
Feb 12, 2010 | Rowenta Irons
Iron will not heat up and the auto off red light keeps flashing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 07, 2009 | Philips HI-296 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Rowenta Effective DX1900 Iron with Auto Shut-off Logo
1,879 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
