SOURCE: SHARP AUDIO XL-MP2H
Are you holding the reset button in for a full 30 seconds? I know it sounds odd, but that's how they're doing it now.
Give it a try and let us know. When you do, please form your reply as adressing the expert in question, such as:
"worldvet: that didn't work any other ideas?"
SOURCE: Lights flash on the unit at night making it hard to sleep!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
SOURCE: I have sharp mini component
Turn the Timer OFF.
http://dl.owneriq.net/a/ac88b963-e6d2-4447-be4d-8e43c83cac5a.pdf
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Please dont forget to vote if you liked my answer
thanks
