Question about HP Photosmart 8250 InkJet Printer
Printer failure I have an HP Photosmart 8250 printer.  After putting a new black (HP0 cartridge in, I get the message error@# Oxc18a001...can this be fixed?
  • 4,041 Answers
Try this
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Hp 8250 printer error Oxc18a020a
try to follow the next steps:
  1. Figure 1: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
Mar 23, 2013 | HP Photosmart 8250 InkJet Printer
Ink system fail Oxc18a001
The "ink system failure" error is caused by air in the ink feed tubes. This happens if you either totally run out of ink and the pump sucks up air from the empty cartridge or you use poorly filled ink cartridges that have sir bubbles. To clear the error you will have to do a feed tube purge. We have a step by step guide to do this posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The purge will take about 10 minutes to do and should get you back up and printing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | HP - HP Photosmart 8250 printer
Printer will not print
please understand that this is an issue with the printer hardware and not the cartridges.so dont waste ur money purchasing new in cartridges hence refer to this document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00723815&cc=us&lc=en&dlc=en&product=1153494
Feb 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure have tried everything such as resetting and nothing works
Have you installed a new cartridge or tried the old one that worked to see if the new cartridge you have was bad out of the box?
Jan 07, 2010 | HP - HP Photosmart 8250 printer
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
Ink failure system error
1. Turn the printer off for few minutes then turn it back on
2. Clean ink cartridge
3. Update drivers
4. If nothing works, repace the battery
Sep 07, 2009 | HP Photosmart 8250 InkJet Printer
HP 8250
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jul 08, 2009 | HP - HP Photosmart 8250 printer
Can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Apr 19, 2009 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
224 people viewed this question
Seeker5211
Seeker5211
