What size filter for a Goodman-model GMS80703AX
What size furnace filter do I need?
mcgyver468
  • 710 Answers
SOURCE: Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Posted on Apr 25, 2009
  • 1214 Answers
SOURCE: Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Posted on Dec 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Posted on Apr 25, 2010
  • 674 Answers
SOURCE: Questionable installation of a Goodman furnace.
That seems to be the common practice. The low pressure created by the suction of the fan will draw air in from outside.
Posted on May 03, 2010
  • 53 Answers
SOURCE: goodman furnace model # GMNT100-4B
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
Posted on May 16, 2010
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Need an gms8, control module .goodman furnace
Go to www.americanhvacparts.com or www.furnaceparts.com On the first site type model number of unit upper right corner and pictures of parts will show on screen. Rus
Mar 14, 2010 | Goodman GMS80904BNA Open Flame Mid-Size...
Filter for Bryant plus 90i
Bryant Furnace Filters www.iaqsource.com Every Bryant filter in stock For every Bryant furnace and AC
may want to check on the filter itself and the housing for numbers that could assist its type and size
this site may help you
Jul 04, 2009 | Goodman CLJ30AR32 Air Conditioner
Apr 23, 2009 | Goodman Heating & Cooling
Need the cubic inches for the return air duct
For proper minimum opening you need to do duct calculation. This is not a typical math equation for the typical homeowner. And unfortunately alot of contractors do not take the time to calculate this.
If you insist on doing this yourself...... I would recommend the largest opening that a common filter will fit. probably 20" by 25". Going to big on a return air will never hurt. But going to small will.
20" x 25" will work safely 95% of the time. But... If you are running airconditioning that is 5 tons in size, you will need the design a return air system that will feed from BOTH sides of the furnace.
If you are just sizing the trunk line you should use a ductulator to calculate the minimum size. A good rule of thumb would be to size the "return air" trunk 1 - 1 1/2 times the size of the supply trunk line.
Mar 01, 2009 | Goodman GDS80904BNA Open Flame Heater
Furnace filter on model gmt070-3a...
look in and around where the blower motor is located. there has to be a filter compartment there. probably near the bottom as it looks like an upflow heater. make sure the filter door is closed. it may have a door interlock switch that cuts the burner out if it is not fully closed.
Feb 01, 2008 | Goodman GMS90703BXA Heater
Furnace Ignitor
At what point does the pilot blow out? Within 5 seconds after it lights or when the room air blower turns on?
Dec 03, 2007 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman GDS80703ANA
Yes, goodman offers a kit. However you will need a gas technician adjust the pressure for you. The whole conversion will take about an hour. The kit may cost $50 and labor is anyone's guess. Call your gas company and give then the model and serial nimber. They can order it and install it.
Nov 19, 2007 | Goodman GDS80703ANA Open Flame Mid-Size...
GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
