Question about HP OfficeJet 6210 All-In-One InkJet Printer
Won't scan, copy, or fax
Says it's running on emergency black ink. It prints 'normal' when I have it set for 'fast draft'.
    Novelist:
  • 140 Answers
You need to change the ink cartridge, the fact that it prints in fast draft is because it does not use as much ink to print as normal letter quality.
Posted on Jan 14, 2009
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
Is there a setting for saving ink when printing pics?
yes,there is a setting on the computer that you can change if you'd like to save on inks when printing photos.you can choose from normal,fast draft or best mode.you can check on these under printers and faxes,righ-tclick on the printer installed on the pc then select printing preferences,properties or advanced tab.
May 27, 2011 | Office Equipment & Supplies
I have an Canon Pixma Mp 496 can i know how much documents can i print with it in fast mode. and also the capacity of those two cartridges
Well, here's what Canon says. In my experience, you can expect to go through a black cartridge in about 500 sheets of paper, less for the color. Our Canon uses ink quickly. The printing speed is pretty fast for a printerthat is for black-and-white documents around 8.4 ipm and a color document printspeed of about 4.8 ipm. While for 4R size photo print takes about 43 seconds.Canon PIXMA MP496 resolution of 4800 x 1200 dpi for (max). It is said the all-in-one, because already integrated between print, scan and copy. For copies, this printer has a speed of around 7.6 cpm for black and white documents, while for the color is obtained at about 2.6 cpm.
Oct 22, 2010 | Office Equipment & Supplies
Can you please help me with this hp photosmart all in oneprinter i have here (model c4472). It always scan and copy documents in black. as in totally black and it consumes all the ink. Please help me i...
start the hp printer setting wizard, go to the ink settings click on normal print settings, change it to use both ink uses, go to the printing settings, go to the draft mode, and rest is work fine
Aug 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
Fast draft printing and 'normal' printing are the same
I'm having the problem too in addition to not being able to print on both sides (duplex printing).
ld
Dec 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Low Ink
I get that when I have just refilled the cartridge, but I usually ignore it and it is still ok for a while; have you checked that you are using draft or normal not best settings?
Jul 29, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
