Question about Sceptre X400BV-FHD 40 in. LCD TV
Sound not working on Sceptre TV
It turns on and everything, but the sound on the tv does not work, went through the menu to make sure it was not muted and it wasnt, how do i fix it
5 Suggested Answers
  • 10 Answers
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Posted on Aug 09, 2009
SOURCE: Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Posted on Feb 17, 2010
spr1949
  • 1182 Answers
SOURCE: sceptre tv: no sound but i have picture
Please check whether sound is coming to headphone. If yes, there is some lose contact in the board. If no, try another input device that you are sure works well. If problem persists, please refer it to a qualified service technician.
Posted on Jul 29, 2012
  • 44073 Answers
SOURCE: i have a sceptre x20sv-gecko with the backlight not working. how can i fix this?
The backlight power supply has to be repaired
Posted on Sep 11, 2012
Samsung tv ct21m17mj
follow this steps and fix it. GOD BLESS YOU
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
No sound:
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 17, 2013 | Televison & Video
Sound won't work
If your TV has a picture but no sound, start by checking the obvious such as whether the mute button is on or whether the volume has been turned all the way down.
Next check your cable connections and make sure everything is plugged in tightly.
Change channels to make sure that it's not a technical difficulty with your TV service provider or TV station. Call your service provider to see if they're experiencing issues with their audio.
Try reconnecting the HDMI cable after you turn off the TV.
Make sure your remote is on the correct input, and see if you have sound while playing a DVD or video game.
For a simple troubleshooting checklist, see No sound on TV and get more details on some simple fixes for this problem. I hope this helps!
Sep 13, 2012 | Mitsubishi WD-73735 Television
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
Sceptre tv: no sound but i have picture
Jul 29, 2012 | Sceptre 32 X320BVHD 32 LCD TV
No audio on Sceptre TV
I think that you missed to check its speakers. Check it. If they are found OK, the audio output section circuit should be troubleshooted.
Jun 11, 2012 | Sceptre X46BV TV
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Sceptre X400BV-FHD 40 in. LCD TV Logo
314 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
