Indesit iwdc 6105 all lights flashing and won't start
2 Suggested Answers
  • 6277 Answers
SOURCE: Hi I have a indesit
It's possibly a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Indesit model widl106 won't spin after the first wash. Lights flash.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 23, 2013 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit model widl106 won't start. Lights flash.
capacitor on motor or windings on motor burnt out
Mar 22, 2012 | Washing Machines
Should the Indesit IWDC 6105 washer dryer give off a burning type odour when running the drying cycle. (it is brand new and condenser)
I have seen some new dryers give off a smell for the first few seconds that they are run for the first time.
If it's any longer then that is not normal.
Aug 02, 2011 | Dryers
Hi I have a indesit IWDC 6105 washer dryer. problem with door lock light. as soon a wash starts light goes off and wash stops and the door unlocks
John C
Jul 14, 2011 | Washing Machines
A few weeks ago the machine (IWDC 6125 S) started to flash against all the options at the top. I had turned it on an off and it was working OK. Just yesterday the door was shut, but the machine would not...
The only quick suggestion I have is to unplug it for several minutes and see if it resets. If not, without any other indicator, the only thing I can think of is the door switch, which should be a fairly easy fix.
Jul 04, 2017 | Indesit W 123 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
