Question about Kyocera 1102LX2US0 model FS-3140MFP Multifunction Printer, Copy, Print. Fax Mono Output Color, Color Scan Output Color, 42 Letter / 33 Legal Maximum Speed, PowerPC440/667 Mhz Processor, 1200 x 1200 dpi Fine 1200 Mode, 1800 x 600 dpi Fast 1200 Mode and 600 x
How to replace the drum on a kyocera fs 3140 - Kyocera 1102LX2US0 model FS-3140MFP Multifunction Printer, Copy, Print. Fax Mono Output Color, Color Scan Output Color, 42 Letter / 33 Legal Maximum Speed, PowerPC440/667 Mhz Processor, 1200 x 1200 dpi Fine 1200 Mode, 1800 x 600 dpi Fast 1200 Mode and 600 x
2 Suggested Answers
  • 40 Answers
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
Posted on Jan 12, 2009
How do i clear jam 20 in fs 3140
You can find it on page 375 of the user manual here: http://www.manualslib.com/manual/450403/Kyocera-Ecosys-Fs-3140mfp.html?page=375
just continue with page 376, 377, 378 to follow the instructions ...
Oct 17, 2014 | Kyocera "FS-3140MFP Printer, Copier, Fax &...
Where is a paper jam in the duplex cover
remove cassette inside underneath there is a green lever pull it down paper should be in there
Jun 27, 2014 | Copystar Kyocera Fs-3140mfp fs-3140 Copier
Search Fixya...MIta 3140 wont receive faxes
make sure your phone line is plugged into the LINE jack, not the EXT jack
Jul 16, 2013 | Kyocera FS-3140MFP Mita FS-3140MFP 42 PPM...
FS-3140 memory full when scanning
change scan defaults to monochrome, pdf, and 300dpi or lower resolution in command center.
Feb 18, 2013 | Kyocera Copystar FS 3140MFP/DP copier
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Solid bar in graph is not fully covered
Hi zmienny
Unfortunetly Kyocera and HP drums not ineter change able. You will have to get the Kyocera fs3800n drum to replace.
Regards
Go-Tech
Dec 16, 2008 | Kyocera Mita FS-3800N Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
Aug 25, 2008 | Kyocera FS-720 Laser Printer
Kyocera 1102LX2US0 model FS-3140MFP Multifunction Printer, Copy, Print. Fax Mono Output Color, Color Scan Output Color, 42 Letter / 33 Legal Maximum Speed, PowerPC440/667 Mhz Processor, 1200 x 1200 dpi Fine 1200 Mode, 1800 x 600 dpi Fast 1200 Mode and 600 x  Logo
370 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
