Question about Vizio L37 Television
Dvd hookup to my vizio 37
Having trouble hooking up my vizio 37 to a dvd no sigal.
  • 3 more comments
  • marvins Jan 13, 2009
    I ALSO HAVE TROUBLE HOOKING UP APEX DVD PLAYER TO MY VIZIO
  • Anonymous Feb 07, 2009
    I have a Vizio 42" and after trying 3 different times, following instructions and talking to people where I purchased my TV, I STILL get no signal when I hook up my DVD player - PLEASE HELP
  • bk395 Feb 08, 2009
    Cant figer out how to hook up my vizio 2 a dvd recorder
  • Anonymous Feb 22, 2009
    When we hook our 42inch vizio tv to our Go dvd we either get no signal or we get the picture and it is black and white.
  • Anonymous Mar 11, 2009
    my vizio is hooked up to my dvd player. I can hear the dvd thru the tv, but no picture. It says "no signal"
Thankyou i fix the dvd by going in the back of the dvd and changeing the wire ot out that was my prolem thank you for the help
Posted on Jan 12, 2009
Posted on Feb 08, 2009
Vizio xvt3d580cm has red contour lines in dark regions of picture. What causes this?
Does it do this using more than one input? Have you tried using a different source such as DVD? IF using HDMI inputs does it do it on all of them? I have seen this trouble because of configuration issues with some satellite boxes also have seen similar issues because of a bad HDMI input.
Oct 13, 2013 | Vizio VO37LHDTV10A 37 in. LCD TV
What plugs do I plug an xbox360 into on a magnavox dvd player
Jesus, not even the red white and yellow hookups? Oh, man, sorry, but I would need the model of the DVD player...and how did you hook up the DVD player if it doesn't have the red white and yellow hookups? just curious. Also I would highly recommend getting a new TV outright. If your tv is that old, it doesn't have HD, and that essentially defeats the whole purpose of having a powerhouse like the xbox 360. If you want the dvd player hooked up, give me the model number, but if you want a new tv, give me a budget and I am positive I can direct you to something reasonable.
P.S. (being tech savvy isn't a requirement for the newer tvs. in my honest opinion, You have to be a WIZARD in order to get all the inputs to convert to the correct format so it can be displayed on the older tv, so hanging onto the old tv is actually more trouble than a new one. Just saying.)
Feb 11, 2012 | Microsoft Video Game Consoles & Games
Where to hook up my dvd player
U look around on the back of ur tv or the side of the tv u see a 3 holes one YELLOW,one RED, one WHITE hole all lable INPUT in a straight in a role that for hook up to the tv if u are using a RCA component cable Y-Video,R-Audio,White-Audio.The other end of the RCA component cable Y,R,W go into DVD player 3 holes Y,R,W OUTPUT holes.
Aug 27, 2011 | Vizio E370VL 37 in. LCD HDTV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
DVD hockup to 37"VIZIO TV
There is no reason that any video player with RCA video/connections cannot be used with your new TV. However, you will not experience any increase in definition, even if your TV is High Definition.
If you used a Component connection from your DVD player (three cables for Video), all that is required is that your TV have Component cable inputs.
Oct 10, 2009 | Vizio L37 Television
Won't record..
try swapping the scart lead to the second AV port on the player sometimes 1 is input and the other output run your tv cable direct to the player and scart to tv hope this helps
May 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot hook up DVD and VCR to Vizio 37 inch flat panel 2003 model
try connecting the output from the sat reciever into the in ant incoming signal of the vcr use the dvd as one of the inputs to the vcr use remote from vcr to switch from vcr to dvd.
hope this helps
Dec 28, 2008 | Vizio L37 Television
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Jan 01, 2008 | Nakamichi DVD-10S
Vizio L37 Television Logo
1,845 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
