Question about Clarion DXZ785USB Car CD/ MP3 Player
Trouble with car stereo
I just bought a clarion dxz785usb head unit. and it will not play cds. it shows that the play time is goin but no sound. the disc is an actually cd not a cd-r. what could it be.
  • 1 more comment
  • Anonymous Mar 21, 2009
    I just bought 3 CDs and none of them will read. Once I select a different source, ie tuner, audio output will begin again.
  • ledhalen May 06, 2009
    Same problem for me..... radio plays fine but cd and ipod = no sound
  • capt42 May 11, 2010
    Point of clarification .. do you mean that NO sound comes from the unit from any source (i.e., radio, mp3/usb input). The problems I have noticed are:
    1. Fuse - depending on your wiring.
    2. The input CD is actually a DVD and burned as a DVD.
Noggin
  • 944 Answers
SOURCE: Error 6 on in car stereo
Here is the link to the user manual for your player if you need it; http://www.clarion.com/gb/en/MungoBlobs/483/874/DXZ838RMP-EU.pdf Page 38 of the manual (page 42 of the pdf file) describes the error codes error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly" Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it Hope this helps :)
Posted on Apr 15, 2007
Eagleeyes
  • 199 Answers
SOURCE: Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
SOURCE: Peugeot 406 (1999) LX + Clarion PU2293A 6-Disc Changer Problem
Bloody snap! I also have a 406. The button on the head unit is supossed to turn on player.My original unit wore out.I got a second hand unit which is also not recognized by the head unit. At the moment I dont know why,but Im not a man to give up easily and will give you the solution when I have it. I know it was working originally and it looks like the secondhand unit is faulty. thomaashamioton@email.com
Posted on Oct 07, 2007
sserpentio
  • 88 Answers
SOURCE: error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Posted on May 21, 2008
HitWizard
  • 67 Answers
SOURCE: Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Posted on Jan 29, 2009
Factory reset Clarion DB338R
It sounds like it is stuck in "Demo Mode" below is a link to the manual for your unit:
https://www.manualslib.com/products/Clarion-Db338r-2814176.html
Dec 20, 2017 | Clarion Car Audio & Video
I have a clarion cy358 car audio system. it has CD am/FM. I wanna know whether what format is compatible with this CD player? Can I play mp3? it doesnt show any mp3 icon on the interface.
it only need to indicate WMA or MP3 when its playing in that format. depending on how old the head unit is... most head units sold after the new ISO-9001 Standards need to display any and all specs http://www.iso.org/iso/about/the_iso_story.htm try burning a data copy first to see if the head unit can search through the folders... if it wont search or do anything at all... its .wave (cd) if the display reads unsupported format and continues to search....it does play mp3/wma to get the mp3/wma files to play, change the settings in the burner program. (try default settings) ..... it takes time to render a nice mp3 disc from scratch, one its working, its really rewarding... 18-20 songs just isnt enough anymore.... try to use 320kbps mp3's as much as you can... anything lower will make ant car stereo sound like a 10 dollar alarm clock... keep the bit-rate high when it comes to music... your ears will last longer too...
Mar 08, 2011 | Clarion Car Audio & Video
I can't get any real bass out of this unit. Iv'e gone thru the manual 20 times and I set the "DZE" off, then adjust the bass to max and it made a little difference. But this unit is suposed to...
Try to exchange one speaker connections only, unplug connector from speaker and put them + to - and - to + pins.
In my opinion, both speakers are giving out of phase sound that cancels the bass sound, speaker connections should be same phase to get bass sound so just change connecting two wires at any one speaker, that will work.
Thanks.
Nov 26, 2010 | Clarion DXZ785USB Car CD/ MP3 Player
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Jul 01, 2009 | Clarion DXZ545MP CD Player
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Jan 29, 2009 | Clarion DXZ375MP CD Player
Clarion APX480M amp
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
Aug 28, 2007 | Clarion APX480M Car Audio Amplifier
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Clarion DXZ785USB Car CD/ MP3 Player Logo
65 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
