Question about Garden
What's the gas mixture I should use in my stihl bg 61 av leaf blower
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
  • 432 Answers
SOURCE: Need to know the gas to oil mixture for a stihl bg
2oz oil / 1gal gas is a good rich mix. you can go up to 2oz oil / 1 1/4 gal. gas. Use only good quality oil.
Posted on Nov 07, 2009
  • 20 Answers
SOURCE: Stihl BG 75 blower doesn't
These units are very promt to gas fouling of spark plugs, try replacing plug. If you still have no spark then possibly the flywheel has a metal strip in it that is prone to rusting, especially if unit does not get used alot, can be cleaned up with 180 or 22 grit sandpaper. If this strip is rusted then coil cannot communicate & therefore you get no spark. Lastly if all above check out good then most likely you have a bad coil. If coil is to be replaced make sure to gap the coil away from flywheel by placing a peice of paper folded over between coil & metal strip-(magnet) coil will pull itself to strip, tighten bolts & remove paper, gap is set.
Posted on Nov 10, 2010
autodidact66
  • 116 Answers
SOURCE: whats the gas ratio mix
50:1 the small bottles to make 1 gallon of fuel are easy to find. hope this helps.
Posted on Nov 13, 2010
  • 640 Answers
SOURCE: Leaf blower #FLI500LE,Starts on primed
I recommend clean and rebuild the carburetor, replacing the diaphrams.
Posted on Aug 24, 2011
Why won't my Stihl blower not run?
check for spark first thing if spark sqiurt some starter fluid in the carb start it if it trys to start rebuild your carb dirty or water in gas dump tank put in fresh mixture not same one again
Aug 26, 2014 | Stihl Owners Instruction Manual Leaf...
Sthil bg 86 blower prime bulb work but blower dies try prime again nothing it put pressure in tak
It could be starving for gas at high rpm.
Check the plastic gas lines between the gas tank and the carburetor.
Replace if even the tiniest crack.
Aug 06, 2014 | Stihl Genuine Sthl Bg 86 Leaf Blower...
Where is the reed valve on stihl bg61av leaf blower
read valves are used by two stroke engines its a V shaped flaps
and is used to feed fuel into the cyclider
it takes the place of a puch rod valve in 2 strokes
and is located at the head end of the intake manifold just after the carborator
Apr 14, 2014 | Stihl Leaf Blower Spare Parts List Manual...
Carb setting stihl bg 61 AV blower
most stihl blowers have 1 or 2 screws near the carb to adjust the idle, try turning a quarter turn while running. not familiar with this particular model. if a rough idle is your only issue with a $2.50 blower, just consider yourself lucky. carb could be gunked up as well. may want to take it apart and have a look, and take the filter out of the exhaust chamber and burn off carbon deposits... not really sure what your question is here
Dec 24, 2013 | Stihl Garden
Download still sh55
http://www.h-machine.jp/part_list/stihl/stihl_BG%2045,%20BG%2046,%20BG%2055,%20BG%2065,%20BG%2085.pdf
Illustrated parts list of BG 45, BG 46, BG 55, SH 55, BG 65, BG 85
including the breakdown of the C1-s50 and C1-s55 carbs
Mar 10, 2013 | Stihl / Zama Blower Carburetor Bg 45 46...
The Stihl 46C will not accelerate and cable and gas is good. Help
Check the spark arrestor, or the exhaust port are not blocked with carbon.
Sep 13, 2012 | Stihl Bg Sh 46 46c 85 85c Blower,...
HOW TO FIX BROKEN ROPE IN PULL START FOR STIHL BG 61 AV LEAF BLOWER?
The pulley the rope goes onto needs to be fully wound against the spring. I usually wind the pulley and hold it with one hand while feeding in the new rope with the other. The pulley may have a cut out on it where you can hook the rope and then wind the pulley. Once the pulley is fully wound by the spring you can hold the end of the extended rope/grip and let it slowly wind back into the recoil assembly.
Aug 22, 2012 | Garden
Why does my Stihl BG 86 Leaf Blower not accelerate?
remove the muffler and run it if ok open the muffler and clean the screen in side they build up with carbon and stop exhaust flow
Jun 15, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Need to know the gas to oil mixture for a stihl bg 55 leaf blower,
Nov 07, 2009 | Garden
Aug 12, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
