Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door sometimes stops during run as if sensor is blocked
I have 1984 Craftsman 1/2 hp garage door opener. Just started having problems - door stops sometimes during travel like sensor is blocked(light blinking), other times runs good. Unplugged to reset - no change, wiring is good. Sensor(s) going bad or opener controls bad?
Thanks
Wipe off the sensor glass with a isopro rubbing alcohol; it should fix it.
Posted on Jan 15, 2009
Craftsman 1/2 hp garage door opener will start to close and after 2-3 seconds it goes back up and there is no obstruction blocking sensors
you may need to adjust limit switches in back of operator.Most of the time with this problem one of the gears inside the operator has stripped out.
Jan 26, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
We have the craftsman 1/2 hp garage door opener and it will only go up 1/4th of the way up and stops. I already reset the unit. One sensor is green and the other is yellow. Cleaned the yellow side sensor,...
The sensors only work when the door is closing. Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
157 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
