Question about Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stacking washer/dryer model #41798702890. Half way into the rinse cycle the washer shuts off full of water. I can turn the dial farther, but nothing happens if it's in the second
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Posted on Feb 08, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Kenmore 110 model purchased in 1987
really? that's unusual...sounds like the mixing of the hot/cold water is not working. could be control panel, or the actual valves.
you particularly handy, or do you usually have someone do this sort of thing.
Apr 25, 2008 | Kenmore 93702 Top Load Stacked Washer /...
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
