Question about Garmin eTrex Vista GPS Receiver
Wait...Tracking Satellites My etrex vista was working perfectly. It suddenly lost satellite signal. It now says "Wait...Locating satellites". This message never goes away. I have turned it off, taken out batteries, used external power, etc. and nothing helps. Also reinstalled latest bios with webupdater.
  • 2 more comments
  • Anonymous Jan 12, 2009
    the same problem
  • Wetstopsine Jan 31, 2009
    dude same thing
  • katti86 Mar 30, 2009
    Same thing! :@
  • Anonymous Apr 14, 2009
    I had the same problem. I was able to get my to work again using the Master Reset described. (I didn't do the Super Master Reset yet, but I might, as my date is still wrong.)
Turning off WAAS and then "Super Master Reset" (then reacquiring signal normally) did the trick for me. Note that it will wipe out ALL saved waypoints, so write 'em down before trying. This link describes it:
http://www.fixya.com/support/t260605-garmin_etrex_vista_date_problem
Posted on Feb 22, 2009
It soes not a acquire a satlelite.
I have this unit and have not had a problem acquiring satellites except under dense canapy cover. In open view you should always be able to acquire enough satellites. You should be able to see the available satellites on the start up screen and watch them being acquired. According to the manual if a satellite fix is not established a list of solutions is suppose to appear. Hope this helps.
Feb 02, 2011 | Garmin eTrex Vista Cx GPS Receiver
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
Garmin eTrex Vista HCx searches for satellites but doesn't find any, since yesterday. Device has worked fine for a few years, has the latest firmware
I have the same problem. Satellite screen shows nothing except the rings. When I open the unit, one of the chip looks like broken; its label says K43 and V5.
Aug 09, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Same problem, wait tracking satellites
make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satelites.
Jul 05, 2009 | Garmin eTrex Legend GPS Receiver
Won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
May 19, 2009 | Garmin eTrex Venture Cx GPS Receiver
Gps not tracking satellites
the antena isnt the greatest, you can get a better external one, or make sure the screen is always pointing up, and your not under tree cover or anything as it will block the signal
Feb 01, 2009 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Locating satellites
Hi cassyd
I have 2 questions in order to help.
1) It can take longer than 30 seconds depending on where you are, how long have you waited for it to acquire?
2) Are you holding the unit verticle while you wait for it to acquire?
If you know your lat/lon you can type that into the position screen while you are waiting for it to acquire, sometimes that helps.
Oct 27, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Vista GPS Receiver Logo
485 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
