Question about Boston Acoustics TVee Model Two TV Speakers
Prgramming ba tvee 26 sound bar to direct tv remote
4 Suggested Answers
  • 6 Answers
SOURCE: need the Boston tvee sound bar repaired. Making
The sound bar system was not adequately tested before release and it's obvious. The sub seems to disconnect and reconnect randomly. This also happens when the bar is off. It makes a large bassy pop every so often when it shuts down. It's woken me up at night when it decided to turn on and off. Occasionally I have to power cycle the sub or even change the frequency in order to re-establish a wireless connection. All of this is an occasional occurrence and poses more of an annoyance than anything. It's crappy to have to say that "It works most of the time." It's too bad because the concept is fantastic, and now I question the quality of Boston Acoustics.
Posted on Feb 21, 2010
SOURCE: I have a TVee model 2 from Boston Acoustics
Hi jdmowen,
I see that you need help since you lost the hardware for setting up you TVee Model Two Speakers.
What hardware are we speaking of? check the links I have provided, one of the links will be the manual and the other links will be where you can get the parts that you might need.
Manual
Parts Boston Acoustic Website
Parts Reseller
Parts Other Resellers
I hope this will help.
send me a message if you need a specific part maybe we can get info for it.
mvincentc
Posted on Jul 04, 2011
  • 3 Answers
SOURCE: Have a BA TVee 25
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Posted on Oct 07, 2011
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
I HAVE A 50" EMERSON T.V. AND I HOOKED UP A SOUND BAR TO IT AQND I DON'T HAVE NO SOUND
Ensure that the output from the TV is feeding the soundbar. Use Settings/Sound/Output in the Main TV Menu.
Dec 02, 2013 | Boston Acoustics TVEEM25 TVee Model 25...
Tv volumn
Are you using another remote for the guide? Like the cable box remote? If that is the case then the remote could be sending a signal to the cable box that is the same as the signal used to adjust the volume on the television.
Apr 30, 2013 | Boston Acoustics TVee Model Two TV...
PROTRON 26 INCH TV SOUND BAR
On some TVs, you have to turn off internal speakers to direct sound to external audio connectors.
Sep 29, 2017 | Protron PLTV-26 26 in. HD-Ready LCD...
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
Not enough IR range to use remote
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Nov 15, 2008 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Model Two TV Speakers Logo
120 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
