Question about Sega Genesis Console
Hooking up a sega genesis to a vizio tv - Sega Genesis Console
    Genius:
  • Sega Master
  • 1,148 Answers
There's a couple ways to hook it to a hdtv...you can use the original one that hooks up with cable wire ..just connect to cable connection on back of tv...switch to channel 3 or 4 on tv...or get the better a/v connecters connect to rca jacks...goodluck
Posted on Jun 03, 2016
4 Suggested Answers
  • 56 Answers
SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Posted on Jul 11, 2008
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
  • 69 Answers
SOURCE: Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Posted on Sep 23, 2009
My sega genisis isn't working on my LCD screen
2q== they have videos on Youtube on how to hook Sega genesis version 1 2 and 3 consoles on up to a flat screen tv or any of the newer TV's. I just use a CRT style TV they are much easier to hook up old consoles too. Just buy a CRT tv type then.
Sep 28, 2013 | Sega Genesis 2 Console
My sega genesis won't work - it was working fine
You screwed it up by plugging it into the 64. It is too old to handle that kind of stuff. I reccomend going and getting youself a Xbox 360 slim. They are much more efficient.
Oct 29, 2012 | Video Game Consoles & Games
I have an old sega genesis and got new plugs to plug it into my 42'' HDMI Vizio. all the plugs are in and the light is on but the screen stays blank. I have tried blowing on the game and got the...
Did you say HDMI? I don't think there are HDMI plugs for Sega Genesis. You can plug in your Sega via composite video through RCA cables (yellow, red white) or via RF signal through coaxial cable. Check your TV's specs to make sure it can display standard definition content via composite or via RF.
You can double check to make sure your Sega Genesis is working properly by plugging it into an old-fashioned CRT (fat tube) television set.
Sep 02, 2011 | Sega Genesis Console
Missing the part that plugs from console to television where do i find?
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
I can't see the picture from the game on my tv
Try hooking up the Genesis to a different TV. If it works, then there's something wrong with the TV or the connector between the Genesis and the TV. If it doesn't work, then the Genesis is most likely on it's way to becoming a paper-weight, or once again the connector could be bad.
Jul 06, 2010 | Sega Genesis 2 Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Sega Genesis Video Problem
Maybe you are supposed to be on Channel 4. There should be a 3-4 switch on your RF adapter. Try wiggling the video connection in the back of your genesis and see if that fixes anything, it might be a lose port, in which case you have to wrap the cable underneath the genesis or something heavy to keep it at a working angle (if you find a working angle).
It is also possible your RF cable is bad. They aren't that much on ebay, but make sure you buy one for your model (there are 2 models of genesis and they use different RF cables)
I hope this helps somewhat.
Jan 07, 2010 | Sega Genesis Console
What is the correct way of hooking up the sega to play I've tried many of ways and failed
throw it all in so it fits if it looks correct TUNE in the channel you want it on.. get an oldish tv if need be
Dec 25, 2009 | Sega Genesis Console
Sep 23, 2009 | Sega Genesis Console
Sega Genesis Console Logo
737 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
