Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi 62525-wavy picture
I have waves in the picture...is it the lamp?
  • Anonymous Mar 30, 2014
    small waves in picture
    Sergeant:
  • 233 Answers
No, this is not the lamp. More than likely you have failing capacitors on your Format (FMT) board, or your DM board.. these Mitsu's are RIDDLED with problems like this - I have one here that the customer did not want to repair, and I cannot justify fixing it for myself even...they have alot of problems with the FMT boards, DM boards, PWB boards, and the actual color wheel itself.. Mitsubishi makes a great set, but I have come to believe the X2525 line and the newer revisions are just as bad...
Posted on Jan 12, 2009
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My picture isnt clear. whats the best color setup?
The best way to clear the picture on these sets is to remove the screen and clean the mirrors. If it is still not clear after that it may be a bad lamp or failing capacitors in the chassis. They cause wavy lines and makes the picture blurry.
Jan 31, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Wavy picture and now has no picture. lamp was replaced.
this set is notorious for defective capacitors. there are many that need to be replaced. I suggest dealing with an authorized mitsubishi servcer for this one.
Jan 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
