Question about GE PSW26SGRSS Side by Side Refrigerator
Water Dispenser works intermintently, Ice dispenser never works
I have a GE Profile (PSC23SGRDSS) side by side fridge with the Arctica front ice and water dispenser. About 50% of the time when I try to get water it will work. When I try to get ice the lights dim and the motor will not turn and no ice will come out. The temperature setting are working great. There are lots of ice cubes in the bin, just the dispenser doesn't work. I think it's most likely the board, but I'd like a little advice from an expert. Thanks
  • 2 more comments
  • karen95355 Jan 19, 2009
    I have the exact same problem. This has been happening for the past 2 years. Now the refrigerator makes a sound like the motor is giving out.
  • russell813 Mar 23, 2009
    GE PSC23SGRD Side by Side. Getting same problem, lots of ice being made but dispenser for both water and ice is working intermittently (actually don't recall when ice dispenser last worked so symptons could be identical to mikemallett's). Light is working, but getting dimmed light when switch is engaged -also notice the panel LEDs go out when press the switch. When I press the dispenser switch, I can hear a solenoid being activated in the back of the fridge, but that's it, no pump or anything like that is being activated. Since this is happening for both water and ice settings, I think I can rule out line freezing as being the cause. Lot's of pressure when things do work, so I know the pump itself is fine and the waterline is okay. I can only presume this is a circuit board problem, but before I spend a bunch on money on a service repair, I was wondering if anyone has any experience with this or can offer up a solution? -Thanks.
  • rvrking May 01, 2009
    Same problem, I'll take Karens advice and call GE for a repair.
    Thanks for the help, I'll call GE.
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Posted on Jan 21, 2009
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
No water from dispenser but ice maker working
You have two sides to the water control valve and it is most likely the dispenser side of your WR57X10051 Dual Water Inlet Valve I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Jul 18, 2009 | GE Profile¿ Arctica® Energy...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSW26SGRSS Side by Side Refrigerator Logo
438 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Alan Moore
Level 1 Expert
