Question about Poulan 25CC Gas BlowerVac
Poulan pro blower bvm200vs repair manual - Poulan 25CC Gas BlowerVac
  • 6 Answers
SOURCE: poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
  • 124 Answers
SOURCE: replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Posted on Sep 14, 2009
  • 11 Answers
SOURCE: My Poulan Pro BVM200VS leaf blower just stopped
sounds like an engine seizure - was there oil mixed with the fuel?
Posted on Oct 25, 2009
SOURCE: reattach pull cord for poulan pro bvm200vs
how to replace cord in apoulan pro gas blower
Posted on Mar 27, 2010
SOURCE: my poulan pro bvm200vs will
Problem is likely a stuck needle valve or ruptured diaphragm causing flooding -- a carburetor rebuild is indicated.
Charlie
Posted on Mar 27, 2011
Can I get a trouble shooting guide for a Poulan Pro leaf blower bvm200vs
the owners manual, available online has some trouble shooting tips...
Oct 18, 2014 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
What spark plug does a poulan bvm200vs blower uses
Go to manualslib.com put in your model number and you can pull up a manual on your model and in spec. sheet it will show you the plug number. Hope this helps.
Jun 11, 2014 | Poulan Pro Gas BlowerVacuum ()
What oil goes in crankcase of poulan leaf blower
Are you sure this is a four stroke engine, i thought all the small blowers were two strokes in which case there is no oil in the crankcase, the lubrication is mixed with the fuel
Feb 19, 2013 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
Poulan pro bvm200vs switch wire harness
They generally ground through one of the screws that hold the cover(s) on to the engine itself.
Aug 09, 2012 | Poulan Pro Bvm200vs 25cc 2-stroke Gas...
Poulan pro bvm200vs, what is the spark plug gap suppossed to be set at?????????????
re: "The plug should be set from the factory check your manual for the gapicon1.png setting"
Chris, If people had the manual do you honestly think they would waste their time looking for the answer online.
Chris - I hope you don't get paid for offering 'Check your manual' answers.
Feb 19, 2011 | Poulan Pro Gas BlowerVacuum ()
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 25CC Gas BlowerVac Logo
286 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
