Question about Samsung Televison & Video
I have a samsung ue40es6800 tv when switching from 3d back to normal 2d (3d off) the picture goes very dark with a strong red hue with a hint of blue. if u switch back to 3d, picture is displayed correctly again. You have to switch the tv into standby then turn back on and picture is normal no problems it only happens when exiting from 3d, changing channels once exited from 3d doesn't correct it.
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
alltechserv.
  • 32 Answers
SOURCE: idlcd32tv27hd comes on for 1 second then goes to standby
REPLACE 2-4 BULGING CAPACITORS IN THE POWER SUPPLY BOARD, PLEASE LET ME KNOW IF FIXED. THANKS
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: Can't exit the menu screen!
you need to do a firmware up date on the tv had the same trouble
Posted on May 15, 2009
freetek
  • 5568 Answers
SOURCE: Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Posted on Jun 15, 2009
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
The picture has hues orf red and appears dark in night shots.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Showing strong blue hue
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 23, 2010 | Hitachi 50UX58B 50" Rear Projection...
Looks like 3D tv
Try doing a calibration. Projection TVs work with 3 picture tubes (Red, Green, Blue). The Red may be off to one side causing the hues.
The manual is available here for instructions on how to perform calibration:
http://www.retrevo.com/samples/Hitachi-manuals.html#Projection%20TV
Apr 06, 2009 | Hitachi Televison & Video
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung PCL545R 54" Rear Projection...
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
