Question about Samsung Dart T499
My samsung dart keeps turning off and on
My samsung dart will stay on for about five minutes then it will shut off and restart
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
Wont stay running afyer changing battery
KAM(keep alive memory) has been cleared, system needs to relearn. Restart vehicle and drive 5 minutes with no loads , then 5 five minutes with everything on, lights ,a/c, radio , and 5 minutes freeway.
Dec 23, 2013 | Ford F-150 Cars & Trucks
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
We just got back from a five hour trip, shut the car off and cooling fan stayed on for about five minutes. I restarted the car, and it went from 200-1500 rpms slowly, shut it off and fan stayed on again....
I have a 2001 S60 and the thermo fans come on after nearly every trip for at least 5 minutes, I would check your coolant levels and certainly change the thermostat if the problem persists.
Nov 28, 2009 | 1997 Volvo 850
My Samsung reclaim keeps shuttin off
try taking out the battery for five minutes
Nov 11, 2009 | Samsung Exclaim M550 Cell Phone
Shuts down after about five minutes and wonr
If it runs really rough before shutting down it is most likely a spark plug.
Jun 29, 2009 | Watts Onan Portable Generator - 4000 ,...
New Samsung sch-430 won't shut off
Mar 30, 2009 | Samsung SCH-u430 Cell Phone
My samsung fridge/freezer srs536np keeps turning off but when i turn power off and backon again it will run , but sometime it can turn off again and if i di the same again it will run
If it is the thermostat from which you are turning it off and then back on again from it is possible that the thermostat is bad and in need of replacement. A thermostat turns off with temperature. Before it will turn back on for cooling the differential must be overcome. If it shuts off at 34°F it will not restart until its temperature reaches the higher built in differential temperature.
Also if you shut the refrigerator off while it is running you should not turn it back to the on position for five to 10 minutes. This is necessary to allow the pressures to equalize with-in the refrigeration system .
May 18, 2008 | Refrigerators
Samsung Dart T499 Logo
289 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
