Question about Dryers
Whirlpool ler5620kq1 electric dryer
My dryer was working fine, until i went dry a load this evening. i pushed the start button and nothing happened. the dryer is plugged in, no circuit is popped, and the door was fully closed.
  • 5,911 Answers
If you have verified the voltage at the wall receptacle and at the terminal block in the back of the dryer to be 220-240VAC, you need to check the Thermal Fuse inside the dryer to determine if it is still good. On your dryer, the thermal fuse is located behind the back panel on the blower fan housing. To access, follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltages are still present inside the dryer with the unit turned off.
2. Remove the dryer vent hose from the back of the dryer.
3. Remove the back panel by loosening all screws holding the panel in place.
4. The blower fan housing will be located on the lower left-hand side (as viewed from the rear).
5. Look for a small white plastic component on the housing. This is the Thermal Fuse.
6. Remove the wire leads and perform a resistance check. If good, the fuse will read about a short (0 ohms). If bad, it must be replaced.
Illustrations of your dryer are available at searspartsdirect.com. Just type in your model number and look for item number 7 under the "Bulkhead" heading. Repairclinic.com and appliancepartspros.com are also excellent sources for finding parts.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 14, 2009
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Doesn't start
Check the door switch. Also it could be bad contact in the timer.
Jul 21, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
283 people viewed this question
Top Dryers Experts
