Question about Honda Pressure Washer PSI 3000
Pressure washer stalls when i pull the trigger
3 Suggested Answers
  • 251 Answers
SOURCE: my pressure washer will start, but when I pull the
hi , first thing to do is a full service on it , clean the air filter , clean the spark plug, check the oil , clean the inline guaze filter on the water inlet side , open the small screw on the bottom of the carb bowl and drain out any water that may be in it , then try it with a water supply but without a hose and lance connected , this will let you know the engine and pump are working , some washers are fitted with a small piston/cylinder comming from the pump with a linkage leading to the carb this may be sticking/jammed , if you post more details we should be able to help
Posted on Mar 08, 2010
  • 26 Answers
SOURCE: my honda pressure washer runs put there is no
Check to see if you have an obstruction in the hose or tip. If clear you have a problem with the unloader valve. This valve sometimes gets stuck and continually recirculates the water not allowing you to build pressure. Sometimes you can remove and clean. If cleaning doesn't work you will need to replace it. Let me know how you make out.
Posted on Jul 21, 2011
My honda xr2600 pressure washer stops running when i pull the trigger
check for a blocked main jet in the carby
the principle is that when the trigger is released there is no pressure in the pump so the engine is idling
when the trigger is pulled the pressure control valve closes the bypass back to the pump and so the motor is loaded up if there is a problem in the carby ,then the motor will stall
Sep 08, 2015 | Honda Garden
Hi I have a homelight UT80546 pressure washer that stalls as soon as I turn the water on. I have replaced the pump with a brand new one that does the same thing. It also has a new carburetor, fyi
My neighbor has one that will do the same thing if the inlet water pressure it too high. I don't know if there is supposed to be a bypass for this water until the trigger is pulled or not. But once the trigger is pulled on the wand the problem goes away. So if you just pull the trigger when turning the water on that should solve your problem.
Oct 02, 2014 | Garden
Motor quits when pull trigger
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Jul 13, 2013 | Campbell Hausfeld PW2102 Gas Pressure...
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Apr 25, 2017 | Porter Cable Garden
Engine idles down and sometimes stalls on pressure washer when trigger on wand is pulled
clean out the carb fuel turns to **** after about 30 day for small engines
Mar 21, 2012 | Briggs & Stratton Garden
PWER WASHER RUNS PERFECT, WHEN WATER COMES ON, IT STALLS. BUT IF YOU PULL TRIGGER BACK ON WAND, THEN SPRAYER WORKS. THE MINUTE YOU LET GO OF TRIGGER, IT STALLS OUT.
hi you have got a fault with the unloader it's not unloading so its going a bove the 13amps and knocking the thermol overload out or blowing a fuse you could cable tie the trigger open or get a new unloader kit costing about £70.00 regards
Feb 17, 2010 | RTO 1800 PSI Pressure Washer
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Mar 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Honda Pressure Washer PSI 3000 Logo
139 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
