Question about Empire Heating & Cooling
Empire rh-65-1 heater pilot light wont stay lit
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 41 Answers
SOURCE: pilot light wont stay lit once heater shuts off/ light goes off randomly
Hi Watertec00,
I am not familiar with this heater but it sounds like it could be a blockage in the main gas line into the heater or perhaps a blockage to the pilot gas line and maybe starving for gas. Best bet first is to check the main gas line from the heater. Easiest way to do this is to remove it from the heater and blow it through with compressed air. Then try the heater again. If that doesn't fix the problem then you can try blowing compressed air down through the pilot line. Could be a little dirt creating a blockage there. Then try the heater again. If it still does the same thing then try removing the panels to expose the heater's piping. If you can remove the main pipe into the heater from the gas and blow compressed air through it it should clear any obstruction from both the main line and the pilot. If this doesn't work then I would think you have a more severe problem and will need to take it to your local Heater Repairer. Hope this helps.
Regards
Bryan
Posted on Dec 22, 2007
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
  • 11 Answers
SOURCE: Pilot light on pool heater
One possible problem to that is a bad pilot generator, not a real common problem but often happens. To test the pilot generator, unhook the to wires that comes from the pilot assembly and hook to the gas valve. Wedge a screwdriver or something in the knob that you push down when regularly lighting the pilot so that gas will continue to flow to the pilot, if you dont hold it down it wont stay lit. Use a multimeter set on DC voltage and put prongs on the ends of the wires. If it is above 600 then it is good, a little bit below will still allow it to work, the pilot only needs like 100 millivolts to stay lit. If it is somewhere down around 500 or lower, then it should be replaced. Another cause, if the pilot generator is not bad, is that a switch in the circuit could be acting up and drawing all of the millivolts from the source before it gets back to the gas valve, in turn the pilot is not supplied with proper millivoltage to stay lit. This usually is the case if you use your heater and it works for a while but then shuts off, and the pilot goes off with it. You can test each switch without removing wires. Each switch should use 5-10 millivolts max. Put one prong on a ground, or just stick it in the ground, the guys i work with dont believe me that it works. And test one side of the switch with the other prong and then the other side to measure the millivolt drop across the switch. If all switches are good. Bad news, probably a gas valve issue. Although take the time to inspect the connections made at the gas valve and all other switches for that matter. A little rust, a little corrosion, can eat up millivoltage very quickly and this can be fix by using some sand paper or emory cloth to clean the terminals. Also check for loose connections, if you can wiggle the wire where it is connecting to the terminal, take it off and crimp it down a little tighter with some channel locks or something. Millivolt heaters are a pain in the but, that is why everybody makes and sells electronic ignition ones now.
Posted on Jan 08, 2009
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Jan 30, 2015 | Empire Heating & Cooling
Pilot won't light on rh-65 vented room heater
The pilot is dirty. You need to take the pilot assembly apart and clean the orfice and hood. Make sure to spray for leaks after the gas valve is in the open position.
Mar 04, 2014 | Empire Comfort Systems RH-65BLP 65,000 BTU...
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
Hard to light, and will not stay lit
Dust in the pilot will cause these to have trouble lighting and staying lit.
Here is a video and photos of where to clean
Dec 28, 2010 | Empire RH35 Mid-Size Heater
Pilot wont stay lit and weak flame
Tap pilot head to knock off any built up corrosion and rust and flame will get better and keep pilot lit
Nov 25, 2010 | Empire DV-35 Heater
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot light does not reach thermocouple
the pilot oriface is blocked it needs cleaning out ,
Jan 13, 2009 | Empire GWT-25 Wall Mounted Panel Heater
Pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
Heating & Cooling Logo
85 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
