Question about Toshiba NB255 Netbook
Pxe-e61 media test failure, check cable
Operating system not found
5 Suggested Answers
  • 298 Answers
SOURCE: My Toshiba satlelite A105 will not boot up ,
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Posted on Apr 08, 2009
benwabnick
  • 2404 Answers
SOURCE: black screen says PXE-E61 Media test failure, check cable, Operating System not found. I hear wierd sounds from the computer.
Sounds like it could be a bad hard drive. With your laptop turned off, take out the hard drive and put it back in and make sure its nice and snug.
Then go ahead and turn on the laptop and see if you can boot back up into windows.
If you can't get into windows and you get the same message then boot up the laptop and go into the BIOS by pressing F2. When you get into the BIOS look and see if your BIOS is recognizing the hard drive, if it's not seeing the hard drive then that means your hard drive is bad and would need to be replaced.
If your hard drive is showing up then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your recovery cd's.
Posted on May 23, 2009
cirocpatel
  • 524 Answers
SOURCE: Pxe-e61: Media test Failure check
in order to load the Operating system I request you to disable the SATA Native Mode in BIOS and then load the Operating system. 1. Please perform the below steps for the same:
a. Restart your computer.
b. When the F10 setup message appears in the lower left corner of the screen, press the F10 key.
c. Locate ‘System Configuration’ and then select ‘Device Configurations’.
d. Under ‘Device Configurations’, select ‘SATA Native Mode’ and disable the same.
e. Save the settings and exit.
Once the SATA Mode is disabled, please install the Operating System in the normal fashion using the Recovery CDs or the Operating System CDs that you have. Before installing the same, you need have the SATA Controller driver. Please follow the ’Installation Instructions’ in the SATA controller driver link given below.
2. Download the latest “Intel SATA AHCI Controller Driver” driver from the below mentioned link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId
=321957&prodSeriesId=3356620&prodNameId=3356622&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ob-54270-1
Upon installing the same, please get back into the BIOS and enable the SATA Native Mode.
Note: The third-party information provided is to help you find the support you need. This information is subject to change without notice. HP in no way guarantees the accuracy of this third-party information. The software manufacturer will provide support for this software.
Please update your observation for us to serve you better.
I have also given you the link below for the XP Professional Drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId
=3356622&prodTypeId=321957&prodSeriesId=3356620&swLang=13&taskId=135&swEnvOID=1093
The above given information are pertaining to HP 6710b Notebook PC. If you do not have the same, please update the serial number for us to given you more information.
Posted on May 03, 2010
SOURCE: I can not get my
hi lawson1377,
it seems it can't find a bootable device in your laptop therefore trying to boot from network.
Get in the BIOS an see if the harddrive is listed and to see if the boot order is correct.
good luck.
Posted on Sep 08, 2010
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
My IBM T20 Notebook is given me this message -PXE-E61: Media test failure, check cable- and then say -Operating System Not Found- ---- What do I do?
The error message PXE-E61 is Network card that try to conect this is because hard drive failure or Operating System
check on the bios if you can see the hard drive if you see the drive it could be the OS
hope it will help
Nov 02, 2010 | IBM ThinkPad T20 2647 Notebook
PXE-E61: media test failure, check cable PXE-MOF: exiting broadcom PXE ROM Operating system not found
The motherboard has died - there is nothing that can be done to save it. Time for a new one.
Oct 10, 2010 | Computers & Internet
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
Aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Sep 28, 2009 | Acer Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
Toshiba NB255 Netbook Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
