Question about Honeywell Hardware & Accessories
Battery change in aube ti033 - Honeywell Hardware & Accessories
3 Suggested Answers
SOURCE: How do I find the instruction manual for the Aube
Open following links to identify Honeywell Aube timer and download manual for T1033:
http://waterheatertimer.org/pdf/Aube-TI033.pdf
http://waterheatertimer.org/Aube-timers-and-manuals.html
Add a comment if T1033U is different from T1033, and describe differences for possible help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Oct 01, 2011
SOURCE: I need the instruction manual for Aube by
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
Dec 28, 2012 | Hardware & Accessories
How do I find the instruction manual for the Aube by Honeywell TI033/U 7-Day Programmable Timer Switch
Oct 01, 2011 | Hardware & Accessories
I need the instruction manual for Aube by Honeywell TI033/U 7-Day Programmable Timer Switch
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
We had a aube timer for years and we changed the outside poll light with a new top somehow when we screwed in the post lamp we hit one of the wires and when i went to turn it on the breaker flipped after...
Aube/Honeywell timers have internal rechargeable battery that powers the display.
Battery is not replaceable. Plus the electronics inside timers are susceptible to power surge.
Without the display, timer cannot be used.
These timers come with standard 1 year limited warranty.
http://waterheatertimer.org/Aube-timers.html
Jul 10, 2011 | Aube Technologies Aube 7-Day Programmable...
The timer no longer working. I can only turn it on and off. It's a model that does not required voltage to work.
You posted under Aube in-wall timer.
If this is not your timer, add a comment.
Aube timers have a rechargeable battery that runs timer functions, and timer does not require 120 volts from circuit.
OK, I wrote to Aube about low temperatures affecting their battery.
Aube said, the battery is good down to freezing, and probably lower.
Lower temperatures cause display to slow down and not function, which means timer programs will not work when timer is exposed to cold temperatures.
Manual override would still work, but not programming or display.
So if timer is NOT located inside warm house, for example timer located in unheated garage or shed, then timer will not function in cold temperatures.
That being said, Aube battery is rechargeable.
If Aube battery has gone bad, then timer is not repairable.
Intermatic ST01C and EJ500 in-wall timers are also battery operated. Intermatic ST01C and EJ500 battery can be replaced.
Almost all plug-in type timers also have a rechargeable battery that is not replaceable.
Several in-wall timers do not require a battery, but they need power from electric circuit.
To see these timers, plus description how to wire this type of timer:
http://waterheatertimer.org/Programmable.html#Aube
Nov 17, 2010 | Aube Technologies Aube 7-Day Programmable...
Lost power and need to reset the timer.
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
If you have different timer, add a comment
Nov 15, 2010 | Aube Technologies Aube 7-Day Programmable...
Need Aube by Honeywell TI032-3W-5/U instructions
http://waterheatertimer.org/pdf/Aube-TI032.pdf
Manual for Aube T1032
Internal rechargeable battery
7 day programmable timer for halogen, incandescent, florescent
Aube T1032 has 40 Watt mim & 500 Watt maximum (5- 100 watt incandescent bulbs etc)
Buy Aube-1033 for heavy 20Amp 2400 Watt maximum
Replaces single-pole switch or 3-way switch (slight modification needed in 2nd 3-way switch)
Buttons
Oct 12, 2010 | Honeywell Aube by TI0323W5U 7Day...
Lost the instructions T1032-33-34-35 can we get them?
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
Oct 06, 2010 | Aube Technologies Aube 7-Day Programmable...
Need instructions for Aube by Honeywell 7-day programmable timer switch
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
Nov 04, 2009 | Aube Technologies Aube 7-Day Programmable...
Hardware & Accessories Logo
171 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
