Question about HP Office Equipment & Supplies
Hi. I am trying to set up my HP7500A and am having issues with the USB connection and setting it up that way. Going through the set up procedure, I get to the bit on the disk where it says about connecting using the USB and I select that, but then the only choices I have to go forward is "BACK" there is no next. Then it has the option to set up the printer later. Thats it. So my question is, how do I set up the printer via usb
  • 11 Answers
SOURCE: set up wireless connection canon mp620
I realize that you posted this question over a month ago...but I'll still give you your answer in case anyone else is also experiencing this.
All you need to do is enter in the correct password...the one you gave your router. Which I realize was probably a while back, and you didn't write it down (tisk tisk), so here's how you find out what you typed, way back when.
open up your internet browser (Internet Explorer, Firefox, Safari, ect...). Now in the search bar type in your routers IP address.
mine is: 192.168.2.1
yours might be the same or might be something similar...like: 192.168.1.1
only type that, and include the dots...no www junk.
once you typed it in, hit enter.
and now you should be in your router...then steps hold true for all routers I believe (mines a belkin).
it will ask for a password, most people simply leave theirs the default password, my password was nothing....literally, I just left it blank and clicked 'next'. yours might be 'admin'...a google search should help you find your routers default password.
Ounce you have the routers password, you have access to change a lot of the routers features...including finding out that pesky passphrase that your in search of.
your welcome.
I accept cash & credit. I'll send you the bill. ;)
Posted on Mar 20, 2009
SOURCE: hpj4680 won't connect wireless to network,
I had the same problem , I entered the configuration of my linksys router and changed from mixed to B+G in the wireless tab and after that, no more problem, it connected rigth away
Posted on Apr 25, 2009
  • 10 Answers
SOURCE: canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Posted on Jul 29, 2009
SOURCE: Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Posted on Dec 13, 2009
HP Xpert
  • 112 Answers
SOURCE: HP Laserjet 3100 all in one USB driver / cable
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Posted on Jan 19, 2010
Hi , I Am using Mercury P1845Z mother board. How can i connect/enable the front panel USB. I tried fixing the pins i the F_USB , but there is no effect. Please help me to resolve this issue
Hi, you maybe need the usb driver from here:
http://www.mercury-pc.com/downloads_list.php?productid=857
Try also to look in the bios in the settings for the usb
it could be set off
The connector look like this you can`t plug it in wrong.
Sep 04, 2011 | Mercury P4VM800M7 Motherboard
Hi! Well,I dl the chipset drivers from emachines site. I cannot connect to the internet,it tries and fails.I have already installed xp service pack 3 from USB. Could this be an issue I haven't validated xp...
The answer has to be in the connection. Your XP doesn't have the right driver set
up for the LAN or 10/100 Set up. Try removing the driver and rebooting the system.
Also once in windows try going to start -run and type in command. Once this widow is open type in >: ping www.wnd.com and see if it 'pings' the web. if not then the issue is back to the driver - modem etc.
Do other pc's access the web on the exact same set up? If yes consider validation and then try again.
You can always re-install but I think you need to check the drivers for the
net work card driver. Good Luck
Gary @ Fix Ya
Aug 10, 2010 | E-Machines T3092 PC Desktop
When I try to capture a video into the imagemixer software, it says it does not recognize the camcorder.
lets see if it's a software issue or not.try to use windows moviemaker as your video capturing software instead of imagemixer. if issue is with imagemixer alone, you may want to uninstall and reinstall and update the software.check website for update: http://support.d-imaging.sony.co.jp/www/disoft/int/pixela/imx/dl/index.html and download the free update for imagemixer ver.1.5 for sony.
if still it's not recognize we can isolate the issue with the camera or connection. if your using usb,make sure you have the usb driver installed properly.you can download the device driver at this website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350 and make sure you don't have the camcorder connected during the installation.also have the usb stream setting (under setup menu) set to on (see:p.221 of your manual). after that the camcorder should be recognized. if your link connection (ieee1394 or dv) it should be a plug-and-play connection. better check computer connections and connected device in device manager screen to see if the cam is listed as an unknown device.if it does, you can be sure nothing is wrong with the usb cable. it can be a connection.issue.try diff ports if available (usb back port at the back is recommended for use, that is directly connected to the motherboard) and check. if the cam doesn't show or you don't have any indication that it's connected.try using a diff usb cable.if still doesn't try using a diff compatible PC.use same procedure.if' it's still the same, unit may require service.hope this helps.thanks:)
Apr 15, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I can print wireless or with a usb connection yet yesterday i could, the only thing that has changed is i have a new router
Hi If you replaced your router your security settings and all other settings will be different. You will need to do uninstall the printer and install it back again or use the Wireless Printer Setup Utility. You can find that by going to start -> all Programs -> Lexmark -> Wireless printer setup Utility and follow the steps to configure your printer on the new router. I believe that you will have to connect the printer via USB to your computer to do this procedure.
Jan 10, 2010 | Lexmark X4650 InkJet Printer
The system would lock up after going into sleep
Try Hard reset remove all the peripherial and power supply connected to the Computer Tower No Mouse, No Keyboard, No Ethernet cable and usb device should connected to the Tower and then press and hold down the power button for 30seconds and then connect only mouse keyboard and power supply to the Tower it should resolve the issue if it will not than set up bench repair this is Hardware issue.
Thanks and Regards
Neeraj Sharma
Oct 16, 2009 | HP Pavilion m7560n PC Desktop
Usb
Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections on your phone.
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Nov 14, 2008 | LG KU990 Viewty
    FORCED FLASH NOT WORKING
    Hi,I know some of the common things for the digital camera. I want you to try these.
    -------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
    -------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
    IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
    * When shooting MPEG movies
    * When set to the Twilight mode
    * If an external flash is connected
    The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
    Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
    Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
    1. Turn off the camera.
    2. Ensure the camera is not connected to an AC power adapter.
    3. Remove the battery from the camera for 15 seconds.
    4. Reinsert the battery.
    5. Turn on the camera.
    If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
    But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
    i hope this helps to fix your problem.
    Thanx for using fixya.
    Aug 14, 2008 | Fuji FinePix Z1 Digital Camera
    Formated Hard drive from Ebay
    Apparently you have tried most if not all of the basic install procedures.
    If and when you connected it as a secondary or slave to a working/booting PC, was it auto detected at the CMOS/BIOS stage? If yes, then perhaps it is a partitioning/formatiing issue, if not then chances are that it is a hardware problem and the drive is dead.
    Alternately, you can try using an external SATA/IDE Interface to USB such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the SATA/IDE connections to your new hard drive as well as a USB cord to your PC's USB port.
    Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
    Good luck and kind regards.
    Jan 14, 2008 | Western Digital Caviar (WD307AA) 30.7 GB...
    Try to setup home wireless network to share two home computer
    Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
    Get back to me when you complete these steps.
    Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
    Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
    Can't get modem to work if I use the USB connection
    Your computer is attempting to find the network connection through your LAN port. Your best bet is to reconfigure your network settings to seek its external network connection through USB, or better still, obtain a router(I personally recommend linksys wireless/basic routers due to stability), and simply use the ethernet connection through it. While this is bypassing the initial issue, it is also saving yourself a lot of hassle when it comes to retooling the PC's settings on the USB connection.
    Jun 04, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
    1,130 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
