Question about Garden
Kubota T1760 mower deck removal how to do it?
4 Suggested Answers
harlan301
  • 205 Answers
SOURCE: my T1760 blows white smoke for 60 sec when starting
it could be your choke stuck, but check you oil level and smell it does it smell like fuel. if so have your carb check out. Little lube on the chock lever. you may want to have your compression check and a leak down test done.
Posted on Oct 11, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
SOURCE: Need a workshop/repair manual for a Kubota T1760
So do I Did you find a solution?
Posted on Oct 22, 2010
Need the front deck wheel and swivel for zd28 60 inch deck
Marvin, check the links below for Kubota deck parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Parts Discount Online Parts Cheap affordable lawnmower parts
http://www.tractorjoe.com/kubota
kubotaParts Online
Kubota Tractor Corporation Parts
Apr 22, 2016 | Garden
How do I replace the main drive belt on a Kubota Lawn Tractor T1760?
Try looking that up on youtube. They have some excellent videos on belt replacement. Luck.
Dec 14, 2015 | Kubota Garden
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
Main spindle needs replacement how to
Typical Kubota mower spindles are mounted with 4 bolts. Some have 4 more on a larger support plate. First the belt pulley must be removed, possibly with the help of a jaw-type puller. Then remove the 4 bolts around the perimeter of the spindle. Using a soft mallet or wood block, drive the spindle assembly down through the deck, making sure there is room underneath for it to fall. Kubota sells replacements as complete assemblies which saves a lot of time vs. rebuilding the spindle.
Oct 05, 2013 | Kubota Garden
How to remove the rear wheel on a Kubota T1760 ride on mower
It is going to need to be lubricated and some patience. Use some PB blaster or Deep Creep penetrating oil. spray it a couple of times a day and let it soak. you may have to do this for several days. They do not put grease on the axle when they put them on.
Jan 14, 2010 | Garden
My T1760 blows white smoke for 60 sec when starting
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
