Question about Air Tools & Compressors
Torque on Kobalt 221565 head gasket
How much torque do I need on the head gasket
5 Suggested Answers
  • 68 Answers
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
Posted on Apr 25, 2009
  • 8404 Answers
SOURCE: Kobalt oil leaking from cylinder
Probably would not hurt to check the bolts ... I would expect a little weeping in this application
Posted on Dec 07, 2009
Testimonial: "Looks right with needing to tighten the bolts and check for leaks. I'll torque to 14-16 lbs-ft like the manual says."
  • 1383 Answers
SOURCE: We've purchased a Kobalt 60 Gallon, Volt 208-240,
Your compressor is designed to be used in a shop situation (not portable) and is usually wired to a switch box similar to how your central air condenser is wired. It can however be wired with a short cord to a 220v plug. Your compressor motor is most likely wired to the pressure switch so all that you need do is to connect your pigtail from the pressure switch to the wall. You can buy all the parts that you will need at Lowes. You will notice that your motor has two wires going thru the contacts of the pressure switch. The inside cover of the switch will clue you in to wiring but if it does not have an illustration just match the black to black and white to white (110 v lines) and green to the ground screw at the pressure switch. Here is a good web site for another view: http://www.ehow.com/how_5041165_wire-air-compressor.html
Posted on Nov 05, 2010
  • 1383 Answers
SOURCE: kobalt 60 gal compressor 221565
266549_300.jpg This is the most popular switch used on compressors but may not be exactly what you pressure switch looks like. You will need to determine how the contacts transfer power across the terminals. Lets number the terminals from left to right 1,2,3,4. On this switch notice how power crosses from 1 to 2 and from 3 to 4. You can determin how power is transfered on your switch by using meter. On this switch, leads from motor (load) would be connected to 1 and 4 and line in ()would be connected to 2 and 3. Determine with meter which leads from your pigtail are 115v each. Pigtails have either 3 or four wires depending on your wall plug configuration. You will only need the two 115v lines (connected to 2 and 3) and a ground wire connected to green screw. Under the cap of the pressure switch, there should be a wiring diagram to assist you for your particular switch. Good luck
Posted on Mar 19, 2011
What kind of oil for kobalt 221565 60 gallon
ordinary engine oil 10/30 or 16 oz synthetic oil ( lowes)
There are compressor oils on the market but as the most it has to do is lubricate the bearings and cylinders , engine oil is quite sufficient to do the job as it has all the additives needed to reduce wear , rust and inhibit moisture from the air compression
if it runs 12 hours a day 7 days a week then there will be a service schedule that you should be aware of but if it is just a home operation then every year or two would be adequate for a service
Jan 09, 2016 | Air Tools & Compressors
How do you replace the head gasket
with great difficultry, It is verry time consuming end verry costly to have it (Replaced)
Nov 27, 2012 | 2000 Kia Sportage
Kobalt 221565 air compressor. Has external oil leak and air leak at head gasket. Leaking oil in to out let air and the valve bleeder under switch will not quit exhausting air while motor is off.
"bleeder under switch will not quit exhausting air while motor is off"
This is an indication of a bad check valve... the Nut-like fitting where the air enters the tank is really the check valve. Half of it is hidden, sticking down into the tank. Oil in the outlet air is most commonly an overfill or use of improper, detergent oil(standard motor oil). Could be also that the piston rings are clogged up with burnt oil. Sounds like you need to remove the pump head to replace a gasket anyway. Remove the valve plate also and clean. Spray carb cleaner down around the piston/cylinder, work the piston back and forth, spray some more. Change your oil using 30w non- detergent oil or synthtic non-foaming 20-50w. .
Oct 09, 2012 | Air Tools & Compressors
HOW TO FIX A BLOWN HEAD GASKIT?
Buy a gasket kit for the upper end. Remove the valve cover intake and exhaust manifolds. Remove the head bolts. Remove head and clean up block from old gasket material. Take the head to a machinist and make sure that it is not warped. If it is warped either replace the head with a new one or have it machined true. Install new gasket and get torque specs with new head bolts and follow torque sequence using the correct torque specs. Clean exhaust, intake and valve cover of old gaskets. install new gaskets and torque according to specifications.
Nov 27, 2010 | 1993 Jeep Cherokee Country
Can i change a leaking top gasket at home? I want to remove the head and have it skimmed.I am reasonally mechanical minded. What is the torque for fastening the top nuts? Manie vd Merwe. Jeffreys Bay
VOLKSWAGONS YOU NEED CYLINDER HEAD REMOVE SEQUENCE AND CYLINDER HEAD TORQUE SEQUENCE.YOU NEED A REPAIR MANUAL FOR TORQUE SEQUENCE OR YOU WILL HAVE HEAD GASKET LEAKS. TORQUE HEAD BOLTS TO * STEP 1 * TORQUE BOLTS 30 FT LBS * STEP TWO * TIGHTEN BOLTS 44 FT LBS STEP 3 TIGHTEN BOLTS PLUS 90 DEGREES.* STEP FOUR* TIGHTEN BOLTS PLUS 90 DEGREES AGAIN.
Oct 02, 2010 | 1999 Volkswagen Jetta
NEED FORD 2.2l head gaskets torque chart
Tighten the head bolts 29 to 32 ft lbs , then tighten again to 59 to 64 ft lbs
Apr 17, 2010 | 1989 Ford Probe
Dec 07, 2009 | Air Tools & Compressors
Kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Jul 23, 2009 | Air Tools & Compressors
Intake to head bolt torque
Intake bolt torque is 11-14 foot pounds. Note:
to torque bolts & nuts, start in center using
crisscross pattern working outward. And as Far as the sealant goes, you shouldn't need any additional sealant since the new gasket has sealant.(just make sure both surfaces are clean an free of oil.) sometimes if the head or the block show signs of pitting on the matteing surfaces then you could use a litttle of that cooper spray gasket to coat the new gasket.
Feb 17, 2009 | 1991 GMC S-15 Jimmy
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
