Question about Sony KDS-55A2020 55" Television
I have a Sony KDS 55A2020 Tv and Directv Sat box with an HDMI cable coming out of it to the Sony TV. Its showing I'm getting 480 now and the question I have is how do I get it to 1080P? Does the TV automaticly find the sorce so the Directv should be set to that 1080P or does the TV need to be set up to 1080P? Chris
  • 43 Answers
First, make sure your signal is in 1080P. Most likely, you have to go into the TV menu and tell it to show in 1080P. Most TVs give you the option.
Posted on Jan 12, 2009
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
Does not switch to its external speakers
You have a cabling and/or setup issue and need to check your hardware manuals (or find them online) for instructions.
I have a Samsung HT-C550, a DirecTV satellite box, a Vizio 37" HDTV, a Sony 5-disk DVD player and a Vizio Blu-Ray DVD player, all peacefully co-existing (with the use of a bunch of cables as well as a Logitech Harmony 700 universal remote).
The TV (not the home theater) controls the use of the TV speakers.
There are multiple options to get this to work. I run an HDMI cable from the sat box to the TV. (HDMI sends audio & video to the TV). I then run an optical cable from the TV to the CT550 and use the "D-In" setting to get the sound to play.
Instead of the optical cable from TV to CT550, you can run audio from the sat/cable box directly to the CT550 using (red/white) RCA cables from the "audio out" jacks on the sat/cable box to the "AUX1" or "AUX2" inputs on the CT550"
Hope this helps!!
Dec 01, 2012 | Samsung HTC550 Theater System
I have directv hd service, I recently bought a surround system, can you help me with the connection? My sat. reciever has an hdmi out as do my surround receiver and my tv
It is always helpful if you give model and make of the equipment involved. We can be more specific and accurate that way.
It si a very straight forward connection and you need two HDMI cables.
1) Connect the Satellite Box's HDMI out to the Receivers HDMI In ( any one of the sockets labeled TV/SAT or Video AUX etc ).
2) Connect the Receiver's HDMI out to the TV's HDMI In.
Every thing will work fine except if you switch off the power of some receivers the TV will stop getting HDMI signals ( ie no sound or video if Receiver is Off )
The other way of connecting is to connect the SAT BOX's HDMI cable directly to the TV's HDMI In and if your SAT BOX has a digital Audio out ( Optical or Coaxial ) connect that to the Receivers Digital In. This way you will need only one HDMI cable and one Optic fiber or Coaxial cable. And the advantage is even if the Receiver is Off you can watch video and hear its sound through the TV.
Apr 03, 2011 | LG 42LH40 LCD TV
Samsung LCD TV LN40A550P3F will not support 1080 format when hooked up to HDMI via Directv receiver.
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
Feb 12, 2011 | Samsung LN40A550 LCD TV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture comes and Goes
bulb is dirty remove and clean if it persists replace bulb.
Jul 05, 2009 | Sony KDS-55A2020 55" Television
Sony KDS-55A2020 55" Television Logo
123 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
