Question about GE Spacemaker JVM1640SJ Microwave Oven
F3 meaning ?
I have a spacemaker xl microwave oven- jvm1430wd002- and F3 appeared on the screen. GE says it needs anew oven sensor. Others say it needs a new keypad. Who is right ? Ca you help me ? thank you. a. roberge
  • GE Master
  • 9,098 Answers
"F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds"
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 12, 2009
Microwave oven fmv145 press clock please flashing when press nothing happen then f3 appears and it beeps
You need a new control board. not hard to repair but it be about even to get a
new unit... take it to a repair shop and will be more than a new microwave and use a a small surge protector for the microwave. cheaper than a new ckt, board next time.
Oct 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error ge Spacemaker xl 1800: Model JVM1851CD. What does F3 mean?
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
Unfortunately, it appears that GE did not make that model to be repaired.
According to the owner's manual, there is a one year warranty.
After that, GE offers no support for it, but they sometimes make exception is people raise heck with Customer Service.
Good luck.
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Get an F3 error
That error means the oven sensor is open. You can test it with an ohm-meter. Then it is either the oven sensor that needs replacement or the control board itself, even if its both replacing them yourself should be cheaper then a repair call.
Thanks,
Lee
May 27, 2009 | GE Profile Spacemaker Over-the-Range...
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
423 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
