Question about Zephyr Savona ZSA-M90S Kitchen Hood
Light blub burnt out
How do you change the light bulb on a savona zephyr hood fan?
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Posted on Jan 15, 2009
Savona zephyr light switch is burn out.How do i replaced it.
Did you ever find a source for the switch assembly? Janderson@andersonpangia.com
Feb 19, 2011 | Zephyr Savona ZSV-E30AS Stainless Steel...
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Dec 13, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Feb 08, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Dec 12, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona
The bulb is a JDRC E27. Google it and you will find various places to get it, such as BulbConnection.com or DivineLighting.com. I would recommend buying 3, because if one has gone, the other will go very soon (my experience) and then you have an extra in case you drop one or one of them fails soon. Shipping will be the same, so the more you buy, the cheaper the per-item shipping. Home Depot does not carry them. Also, I don't know the differrence between the JDRC and JDR, so if you get the JDR version you may be displeased. Also, before getting the LED types, check the brightness... when I bought mine, the LED's were not very potent, so I stuck with the Halogens. However, they are very warm.
Apr 23, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona ZSA-M90S Kitchen Hood Logo
1,461 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
