Question about Dell Dimension XPS PC Desktop
DVD won't eject on my Dell XPS
Put the DVD with pictures in the computer and now it won't eject it.
Fixe_You
  • 1800 Answers
SOURCE: Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Posted on Dec 29, 2008
SOURCE: Need to replace the CD/DVD combo. It will not
Any SATA DVD combo should work they are all industry standards.
Posted on Jan 26, 2010
grantg1983
  • 218 Answers
SOURCE: when I insert a cd/dvd in my drive, it makes a
sounds like the drive has failed try the person whom you got the computer from for a new one
Posted on Jul 12, 2010
Jagergab
  • 25 Answers
SOURCE: Machine won't start - so
You may not be able to eject CDs or DVDs from your computer, either using the Windows Eject feature or by pressing the button on the drive. If the Recommended Solution above does not automatically return your drive to a working state, try these options:
  1. Attempt to Eject the CD in System Setup. Software may be interfering with the normal operation of the drive. Reboot the computer and tap the F1 key while at the Dell logo screen to enter System Setup. Then attempt to eject the CD tray using the button on the drive. If the drive ejects properly, there is a software conflict that needs to be resolved.
  2. Try a Diagnostic Startup. If the drive ejects normally in System Setup, try a Diagnostic Startup of Windows 7.
    1. In Windows, click Start, then in the Search box type msconfig and hit .
    2. Click Diagnostic Startup to load basic devices and services only.
    3. Reboot the computer and try to eject the drive when you get back into Windows 7.
    If the drive ejects correctly, look for burning software that may be controlling the drive and update it or uninstall it.
  3. Reseat the drive. The cabling of the drive may be loose, or the drive may not be seated correctly in the laptop. Refer to the Online User's Guide for your computer for information on reseating the cables or the drive in the computer.
  4. Update the optical drive firmware and the BIOS on the computer. In some instances the firmware of the drive may become corrupted or the BIOS may 'lose' the drive. Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
Posted on Mar 24, 2011
  • 998 Answers
SOURCE: Problem with the Dell XPS One All-in-One the
See if you can boot from a CD disk by pressing the key and then selecting boot from DVD/CD drive.
You should have a CD that came with the computer which has "Diagnostics and Utilities" listed
under "Contents".
If the computer boots with the CD and the CD disk is not being accessed and before, you have a
software issue.
Posted on Jun 28, 2011
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Can't eject dvd from dell xps 27
I had this problem, talked to a Dell support person for two hours with no success. Went to bed, next morning, I powered the desktop off (not restart) with the power button. The first time, the DVD drive cranked up but didn't eject the disk. The second time I powered it off and then on again, the DVD drive ejected the disk.
Jan 11, 2013 | Dell XPS M1530 Notebook
Dell xps 400 dvd/cd drive door won't eject or
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 26, 2012 | Dell Computers & Internet
CD stuck in disk drive and won't eject. Computer is XPS M1530
Manually eject:
1. There is a small hole on every CD drive
2. Take a paper clip and on fold it
3. Stick it into the hole on the CD drive
Additional Reference
Instructions on how to manually eject a CD drive
Best Regards,
Embraced Support
Fort Lauderdale computer repair
Sep 05, 2011 | Dell XPS M1530 Notebook
CD or DVD does not stay in slot. Computer ejects it without reading.
The Dell™ XPS One™ A2010 system features an enhanced one-time boot menu that is easily accessible by pressing at the Dell™ logo during POST. The options in the boot menu are:
  • SATA:3M-WDC WD2500AAJS-75RYA0
  • CD.DVD:3S-TEAC DVD+/-RW DVW28
  • Network:IBA GE Slot 00C8 v1250
  • Dell Diagnostic Partition
Try to boot from a boot-able CD such as the Dell Resource CD. If it still ejects the CD then your CD/DVD drive needs to be replaced.
Jul 26, 2011 | Dell XPS One All-in-One TV Desktop with...
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
My laptop won`t eject the cd
if you look on the drive youll see a very small hole, unfold a paper clip and push it in carefully, that will manually eject the drive
let me know how you get on
Apr 29, 2009 | Dell XPS M1530 Laptop
2/replace the part.
Dec 29, 2008 | Dell XPS 200 PC Desktop
My Walmart Computer Care Plan CD is to small/My Dell XPS M1530 CD drive won"t '****' in the CD disk
Call the phone # on the brochure or your service plan and they will send a full size disk for free.
Dec 07, 2008 | Dell XPS M1530 Notebook
Dell Dimension XPS PC Desktop Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
