Question about RCA D52W19 52" Rear Projection Television
TV tries to come on 3 times
My TV made a loud pop one day, and now when I try to turn it on, the light comes on (sounds of electricity, or tv firing up in the back), then goes off. It repeats this 3 times, then I must wait about a minute to try again. After 3 to 15 times, it will eventually come on.
  • Josh Wiles Jun 10, 2007
    Is there a way I can discharge it, so I can take a look? And what can I touch safely without discharging it?
  • Josh Wiles Jun 11, 2007
    I believe I know the board you are talking about. Does it have a block like thing on it that sounds like electricity is going through when you press the power? Around that block on the board, it looks dark, almost as if it was burnt. And the board itself seems to be warped some, maybe its not though.
  • 203 Answers
The load pop was something blowing in the unit. I would take the tv to a repair center. http://direct.where2getit.com/cwc/apps/w2gi.php?client=rcathomson&template=searchretail_new
Posted on Jun 09, 2007
  • Benjamin Madison
    Benjamin Madison Jun 10, 2007
    I'm hesitant to tell you that anything is safe since there is an issue in the unit. Typically a TV will discharge itself, save for a few item (Tubes, P/S caps, etc) My guess is there is something in the HV section that has gone bad. Once the back of the TV is off it'll be the board on the far left. If something made an audible pop theoretically there should be a visible sign.
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
POP goes the Plasma
You've lost the standby voltage, probably due to varactor or passive component failure...accordianman
Feb 26, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
